Horn - NewBeetle.org Forums
Old 08-17-2006, 02:18 PM
Unhappy Horn
Okay guys,
I've been to the VW dealer six times now.
Let me first say my horn stopped working when I was disabling my DRL's. I disabled the DRL's by pulling the relay "173" all was well. Then a few days later notice my horn did not work when someone cut me off on HW 75.
I don't know if it is a coincident or it’s related to something I did by removing the DRL relay, but the fact is it does not work!
I have now replaced the two people mover horns (high and low range) the relay for the fog lights/horn "53" and still no horn. The dealer said they have no idea what to check for next. I stumped!!!!
Can anyone suggest anything to try?
Thanks
HD
FYI - I have a 2002 1.8 turbo
Old 08-17-2006, 06:38 PM
kcfoxie's Avatar
I'm not a girl. Sorry!
Durham, NC, USA
Car: 2003 New Beetle TDI
This may sound stupid but did you check the fuses?
Phoenix: 2003 Uni-Red New Beetle GLS TDI 132k former-automatic with a 1998 TDI Manual Transmission swap.
Old 08-17-2006, 08:23 PM
I checked every relay and all 43 fuses!!!!
I'm thinking it's in the steering wheel.
Hummmm
Old 08-30-2006, 08:52 PM
Question Horn
I finely got the air bag off and replaced the horn contacts and then reassembled everything. Guess What?
Still NO damn HORN!!!!!
I don't get it…..
I have now replaced the horns the relay and the contacts in the steering wheel. What else is there?????
Old 08-30-2006, 10:42 PM
I too have a horn problem. The only time the horn works is when you use the key fob to lock/unlock the car. Other than lock or unlocking the car using the key fob you can push on the horn all you want and new get it to blow. Any ideas out there?
Old 08-30-2006, 11:59 PM
There are two different horns. One for the alarm and one for the steering wheel.
My alarm hard works FINE!!! It's the steering wheel horn which does not work!!!!!
Old 08-31-2006, 12:38 AM
Where are the horns located? Are both located together? I have the Volkswagen New Beetle Service Manual by Bently Publisher but I can't locate any reference to the horns. I am having the same problem. The alarm horn works fine but the steering wheel horn does not. I think the contact in the steering wheel works because you can hear the contacts in the relay close when you depress the horn button in the steering wheel but still no horn. Now that I know there are 2 seperate horns all I need to do is locate the horns and how to access them. What parts and pieces have to be removed to gain access.
Old 08-31-2006, 02:06 AM
Actually there are three horns. I have the manual to and your right there is no reference. There are two horns located in the front drivers side finder well for the steering wheel horn. There is also one right in front of the passenger’s side front seat under the hood; this one is for the alarm.
Old 08-31-2006, 02:17 AM
Any ideas on how to access the horns for the steering wheel?
Old 08-31-2006, 02:27 PM
This is what I did; I removed the front left wheel (driver’s side) and then remover the finder well plastic lining. Then voila!!! There they are just to the left.
Old 08-31-2006, 04:06 PM
I will take a look this weekend when I have a chance. I think this may solve the problem. I believe I am getting a good connection from the steering wheel through the relay (clicking noise at relay) when horn button is depressed and up to the horns. I may just have some bad horns. If that is true I will be looking for a used pair. Thanks
Old 08-31-2006, 04:13 PM
Unhappy
My relay does not click when the horn is pressed????????
It's like there is no POWER at all!!!!
hummmmmmm.
Old 08-31-2006, 04:16 PM
what's the odds of both horns going out at the same time???
Old 09-09-2006, 02:28 AM
Default Both horns dead
I find it hard to believe that both horns could fail at the same time but they did. I found a pair on ebay and removed and replaced them and they worked. For a year I had been putting off taking it to the dealer for repair but this forum told me where the horns were located how to remove them and all is well now.
Old 01-28-2010, 02:46 PM
reviving this dead thread. im having the same no sound from the horns problem. Pushing the horn results in no clicking as well. Is the relay easily accessed and replaced?
Old 01-29-2010, 05:00 AM
Twizzler
Toronto, Ontario, Canada
Car: 2002 NB 1.8 GLX RED
I've had no horns for about two years now. It originally started with the low tone horn, it would sound shorted when pushed. Eventually it would no longer work, only the higher tone was working. Then one day it stopped as well. Dealer could not find what was wrong so I gave up. I replaced the relay/fuse/horns/clock spring contact in steering wheel and measured current flow at the wires that connect to the horns themselves and there is no current now. I think the horn wires are cut somewhere after the relay. I am going to once and for all trace these down when I have time and post what I've found. On a side note I have a pack of Dixie air horns I'm going to install that should compensate. I'm going to own a Hazzard county Beetle!!!
Installing Old Style Horn Big Paws Styling Modifications 17 11-15-2009 12:57 AM
Horn Replacement fohveh Questions, Issues, Concerns, or Problems with the New Beetle 6 12-27-2006 07:06 PM
Horn! Mister Styling Modifications 5 07-27-2006 02:09 PM
Horn Location. dvious Technical Modifications 18 05-04-2006 07:55 AM
Horn relay location? bigsnack 1.8 Liter Turbo 0 12-15-2005 10:44 PM
