Hi all, driving along today I got a red flashing temp light on my 1.8T. No CELs, EPC, etc... just temp. Of course pulled off at the next exit and checked coolant level. It was at the bottom of the resevior! Filled it up an inch or two with water/coolant mix (I know... G12 only, but better than overheating the engine).
Light went out, but when at home I noticed coolant leaking down the side of the block (small drips like water drops when you run some cars AC). It only seems to be leaking with the engine running, so 90% certain it is the water pump. I have the metalman timing belt/water pump kit coming this week, do you all think it is safe to drive for ~100 miles till I get the parts and get an appointment at the stealership? As long as there is coolant running through the system is it that bad? Anyone else see a slow leak like this before? Thanks! ![]()
How-To: EPC/Brake light switch fix How-To: Coolant Temp Sensor replacement - p1296 www.ivdub.com/markbug My Bugs: 07 Triple Black Convertible 01 Yellow GL 2.0 (retired) 00 Black GLX 1.8T (retired) 02 Black Turbo S (retired) |
As long as there is coolant in it (better get some G12 for the trunk!), it is safe to drive for a day or two? |
If you're very vigilant about checking and topping up your level you may be O.K. I'd carry a jug of pre-mixed 50/50 coolant/water on board. If it's the water pump though, maybe there's some possibility of the impeller/moving parts shattering and doing damage?
Help me out here, mechanic gurus ![]()
| Leaking Coolant, Help!!! | GraceIsotope | 1.8 Liter Turbo | 3 | 07-28-2006 12:22 AM |
| Leaking Coolant, Help!!! | GraceIsotope | New Member Forum | 5 | 07-28-2006 12:18 AM |
| Coolant leaking | bdlbug | 2.0 Liter Gas | 4 | 10-26-2005 12:25 AM |
| Coolant leaking from flange (heart valve?) | rcy | Questions, Issues, Concerns, or Problems with the New Beetle | 5 | 10-15-2005 03:11 AM |
| EVAP leaking?? | Naen | 1.8 Liter Turbo | 9 | 10-06-2005 01:12 AM |
