I am having some issues tring to figure out what is causing the spoiler to get stuck in the up position. I just lubed the track with some lithum grease. but I see nothing causing it to get stuck. It isn't all the time. when I manually raise and lower the spoiler. going up is like butta, but when I lower it. it will move, stick,move,stick,move,stick, and completely close ...very weard ! Have any of you all had a issue like this ? I have searched ,and I couldn't find anything talking abut my problem. there is no cell lights on for the spoiler having a problem. so it as me woundering if there is something I am over looking. thanks for your help and info in advance.chris
http://myspace.com/2006ufgators |
It moves down slowly when the car is at idle to prevent pinched fingers. Closing, stopping, closing, stopping, until it is finally closed.
If you have lubed it up, raise and lower it several times to get things moving smoothly. Mabey someone here can post lube points for the spoiler...
How-To: EPC/Brake light switch fix How-To: Coolant Temp Sensor replacement - p1296 www.ivdub.com/markbug My Bugs: 07 Triple Black Convertible 01 Yellow GL 2.0 (retired) 00 Black GLX 1.8T (retired) 02 Black Turbo S (retired) |
Yup, that's by design. No amount of lubing will correct it.
At normal highway speeds, it goes down in one motion. I believe anywhere below 10mph, it will due the multi-step approach.
Cyber Green. It's not a color. It's a way of life. '00 GLX Cyber Green / Cream, 5sp. (Click for pics!) '07 Audi A3 S-Line |
If you have lubed it up, raise and lower it several times to get things moving smoothly. Mabey someone here can post lube points for the spoiler...[/QUOTE]
that would be nice. but before this started the other day. the spoiler would go up, and down the same way.(speed wise) only at idle it does the close, stop, close, stop, close... |
| Turbo S spoiler switch | keegiam | Questions, Issues, Concerns, or Problems with the New Beetle | 16 | 11-20-2006 12:16 AM |
| Turbo Spoiler hatch on a regular Beetle? | MrPolak | Technical Modifications | 11 | 10-20-2006 02:50 AM |
| uf_gators 2K2 NB Turbo S | uf_gators | Photos: New Beetles | 2 | 04-15-2006 06:59 PM |
| Rear Spoiler on '01 GLX Turbo | heeeheee | 1.8 Liter Turbo | 8 | 11-04-2005 06:10 PM |
