Limp Mode? - NewBeetle.org Forums
Old 12-12-2006, 02:29 AM
FallinApartBoy's Avatar
I Want A 2.5T
Dayton, OH, USA
Default Limp Mode?
ok does anyone know what this is like? i was wondering cause when i shift (i believe usually from 2-3) i feel like a really bad stall like where it doesnt want to do anything. then its just fine. i didnt know if this was limp mode or not. what psi does it hit at? how do i fix it?
Old 12-12-2006, 02:54 AM
NYBugman's Avatar
MkV Pilot
Brooklyn, NY,
Car: 08 CW GTI Pkg1 DSG
limp mode is when you can't boost over 5psi in any gear.
Sounds like you may have problems with the throttle body. My car is in the shop right now for a bad throttle body. It's not a cheap fix if it is the problem.
Any lights? Codes?
Old 12-12-2006, 05:23 AM
Lnzbug's Avatar
MINI & NB FOR LIFE!
Arlington Heights, IL, USA
Limp mode for me was a drop in boost power at 3k rpm. Kinda like you took your foot off the gas. Did you get a CEL? If you did go to autozone and let them scan it and tell us what codes come up.
Old 12-12-2006, 06:15 AM
digitalputty's Avatar
Where is home ....
Lone Tree, Greeley, USA
Car: 2003.5 GLS BLCC (Zoomer)
What causes limp mode? And when in limp mode does it always stay in limp mode ... *heh*
J'veux pas mourir tout seule.
Old 12-12-2006, 01:09 PM
I Want A 2.5T
Dayton, OH, USA
no codes or anything. but when i switch gears it feels like a slam on the brakes. just between those 2 gears i think and only when i am really getting on it.
Old 12-12-2006, 07:14 PM
jackfrost's Avatar
and your little dog too!!
Gurnee, IL, USA
Car: 2000 Cool White glx
first thing i would get would be a boost guage and watch your boost. could just be lag or even a vacuum leak.
Rest in peace rich, no one will ever forget you. fo' shizzle mate......fo' shizzle
quicker than quick, faster than fast i am...wtf, im on fire AAAAAAACK
Old 12-12-2006, 07:26 PM
Denver, CO, USA
Car: 03 Turbo S
find some1 with a VAG-COM... you'll know your in limp mode because it will be like driving a 2.0L there is practically no boost at all.
the cag can do a throttle body alignemt for you and also get the codes for you...
good luck
Turbo that Shiz yo
03 Platinum Grey Turbo S
Old 12-14-2006, 04:13 AM
SilverSportNOLA's Avatar
Faster Than Katrina
Formerly New Orleans, LA, USA
Car: 01 Sport
It usually resets when you turn the key off and restart. I have only heard this ... never have had limp mode and Happy at 18-19PSI Max.
Cause ... boost exceeding either 21 or 23psi ... usually seen in cars that someone has been swapping N75 valves, or with manual boost controllers, but I am sure a busted vacuum line on one of the N valves could cause it also.
Old 12-14-2006, 06:33 AM
Holland's Avatar
Beetle Is Bad As Can
Arcadia, CA, USA
Car: 2000 1.8T Beetle
Your MAF or TB is going bad... my guess it TB... Thats not limp mode at all.... Try cleaning it.... Also have someone check the soft codes with a VAG.. This my sound kinda lame but does it go away with the traction control off? When you start making some good power and the car spins the tires alot the traction control makes the car feel like it shuts off..
2000 Reflex Yellow 1.8T GLX Mods, O2M 6 speed, EFI systrms DFI, GT30 Turbo, MBC, 62ibs Injectors, 3in Downpipe and Exhaust,custom water/air ic, ATP Exhaust Manfold, ATP Fuel Pump,Adjustable FP Reg, AutoTech steel flywheel W/Power Clutch, and HKs BOV, stroked to 2.0L, ported head W/shrick cams. 11,70@122..Dyno 409HP 370TQ @ 12PSI on 116 Octane. Other cars, 07 Tahoe LTZ and 06 620HP LS2 427ci GTO..FTI cam,AFR Heads,FAST Intake,Kooks Headers, and 175 NX Nitrous..9.73@142 on nitrous..
Old 12-21-2006, 09:43 PM
nyum96's Avatar
HotLanta, GA, USA
Car: 01 Beetle 1.8T APH
What about the MAP sensor on the intercooler?
limp mode help!!!!!! GENETIX RACING 1.8 Liter Turbo 7 01-28-2007 01:41 PM
How I Can Get Out The Safe Mode Of My Stereo DUENDEPUNKER New Member Forum 3 11-08-2006 03:57 AM
When Should You Use Sport Mode Transmission? Moviequill Miscellaneous Hoo-Ha Archive 7 10-30-2006 05:51 PM
"limp Mode"????? silver01beetle 1.8 Liter Turbo 13 07-21-2006 02:59 AM
