If you take your Bug to the Dyno, you'll definitely want to press that button and turn it off or the system will not allow you to rev the engine with the parking brake engaged. Yeah...we learned that one from experience.
Aphid has been with us since Sept 7, 2002, and even with over 100,000 miles, she's still going strong! |
Lucky it did not rain that much and I drive slowly.... ... now I am going in a corner hiding in shame .... ![]()
NEKO - The northen California Cat http://www.newbeetle.org/forums/showthread.php?t=10789 |
I call it the burn out button
2000 Reflex Yellow 1.8T GLX Mods, O2M 6 speed, EFI systrms DFI, GT30 Turbo, MBC, 62ibs Injectors, 3in Downpipe and Exhaust,custom water/air ic, ATP Exhaust Manfold, ATP Fuel Pump,Adjustable FP Reg, AutoTech steel flywheel W/Power Clutch, and HKs BOV, stroked to 2.0L, ported head W/shrick cams. 11,70@122..Dyno 409HP 370TQ @ 12PSI on 116 Octane. Other cars, 07 Tahoe LTZ and 06 620HP LS2 427ci GTO..FTI cam,AFR Heads,FAST Intake,Kooks Headers, and 175 NX Nitrous..9.73@142 on nitrous.. |
when we were in the car with the salesman giving us the final "walk-around" speech, he told us to push it on and never touch it again
"Anytime I see something screech across a room and latch onto someones neck, and the guy screams and tries to get it off, I have to laugh, because what is that thing.." - Jack Handey our NB http://newbeetle.org/forums/showthre...ght=moviequill Online blog http://moviequill.blogspot.com/ Facebookhttp://www.facebook.com/profile.php?id=708535589 |
Or in other words....don't touch the button because you do not need to no matter what you're doing unless you are trying to do something specific like a burnout, dyno, etc. Basically that button is used by the car nuts.
I do not have one. Kinda wish i did though.
If you see the light in the instrument cluster blink on a rainy day, that is the ASR kicking in. When you depress the button on the dash and the light comes on, you have not turned it off. What you have done is raise the level of how much wheel spin is now going to be allowed. If you got stuck in a snow rut, ASR will keep killing the power to the wheels, you'll have to rock back and forth to get out, thus hit the button to raise the level of how much wheel spin is allowed so you can get going. However, if your are driving down the road and a puppy dog jumps out in front of your car and you swerve, ASR won't help you at all... if you loose control, then you loose control. There is another system called "ESP" which if the puppy dog jumped out in front of you and you swerve, then it will try to maintain control of the car.... ESP can control each wheel brake seperatly, it monitors how much steering wheel input you are giving, each wheel's speed, lateral force of a turn. Then based on that info, it will cut power output of the engine and apply seperate amounts of force for each wheel to try and keep the car on course that you are aiming for. Later.
| Pics For The Curious | Too Cold NB1.8T | Styling Modifications | 91 | 08-16-2010 01:18 PM |
| Curious George and the VW | Oyveychris | Miscellaneous Hoo-Ha Archive | 10 | 02-13-2006 09:05 PM |
