2.0 turbo's weren't factory engines in 2001.
IF it's a 2.0 turbo from 2001, it was done after-market. Probably doesn't have a spoiler. You should be able to see the 4" black piece at the top of the rear glass. If you see it; that started as a 1.8t. |
That is not 2.0 .... it says 20 Valve Turbo, actually I think it is 20V Turbo, I have had a few Ricers think it was a 20 Volt Turbo ... like I would put that eBay electric supercharger in my car. There is no 2.0 Turbo Beetle ... the 2.0T is in the 06 GTI and GLI ... Only Beetle with a Turbo in new 06 body style is the Diesel. Take a picture of it and post it here. It it is a turbo engine, the cover will be all black plastic ... on the 2.0 or 2.slo Normally Aspirated engine the cover is black plastic but you can see the aluminum intake runners.
I may be wrong(not likely, I'm never wrong
) But either it's a 2.0 no turbo OR 1.8t turbo. It's one or the other. Unless the turbo was added not by VW. Rear hatches can be switched easily enough. Run your hand under the steering wheel. If it's a turbo you will find the rocker switch about 8 or so inches below it.Like he said, 20V (valves) But I have a 2001 and it says 1.8turbo. I don't know what years had that engine cover.
Lnz .... they changed it about 01.5 to 20V Turbo. I think it was the AWV Engines that had the 20V ... but there where probably a few of each engine type with the other cover during the transition ... I think PaulT's is one of them.
| 2001 NB Headlight question...among other things. | theatredivachu | Questions, Issues, Concerns, or Problems with the New Beetle | 10 | 11-26-2006 11:23 PM |
| pcv valve question and oil question | a_magoo | 1.8 Liter Turbo | 3 | 10-07-2006 01:31 AM |
| I have a 2001 1.8t how new can I go to swap? | Lnzbug | 1.8 Liter Turbo | 4 | 08-28-2006 07:34 PM |
| p 0411 code question and coolant leak question.... | bobbittle | 1.8 Liter Turbo | 5 | 06-12-2006 02:47 PM |
| WTB: 2001.5-up NB 1.8T | The Cheat | Market Place Archives | 0 | 04-21-2006 08:59 AM |
