My 2000 1.8T Beetle died on me. I was driving down the street and hit the gas and I heard a "thud/pop" noise from the passenger side of the engine. The car imeadiately began to misfire and shut down. I pulled over and looked under the car and saw that a rubber hose that connects to the turbo charger (about a 3" diameter) had come off and oil was leaking from it. Any idea what's going on? Have I blown my turbo? Anyone can tell me how to replace the turbo? Thanks in advance!!!!!
Pics would help. How much oil was there? That is also important. Here is a KO3S replacement DIY (without pictures) Here's a KO4 install on an Audi TT (with lots of pictures)...This is a FANTASTIC write-up! If you have to replace the turbo, I would suggest a KO3S turbo (from a later model car) It has a KO4 compressor wheel, and generates more boost.
all you did was blow a hose off. Probably because of a loose connection from the factory or some other random occurance. Put it back on and clamp it tight and you should be fine.
Looks like someone put a shreader clamp on there already. That hose may be damaged from it, that worm clamp is not OEM ... I can't tell from the pix .... but if it is a Gator Clamp you should not have any shreading of the hose. Clamp it back down ... check it with each oil change to make sure it is tight, I still have all the OEM plumbing on that side and have been putting 18 - 20 PSI through it for almost 2 years without a problem like that.
Ok, I've put the hose back on and everything seems to be fine. How will I know when the turbo is getting ready to die?? Thanks for all of the help!!! Oh, and Merry Christmas!
You will know after it dies. Turbo failure on stock cars is not terribly common. Don't worry about it. |
| Hello everyone, i'm in desperate need of help | Carlitoslpz | New Member Forum | 4 | 09-05-2006 11:32 PM |
| Desperate Housewives | Severecaraddict | Miscellaneous Hoo-Ha Archive | 19 | 11-09-2005 12:50 AM |
