Getting ECU upgraded, what should be double checked? - NewBeetle.org Forums
Old 03-10-2007, 05:17 PM
kurros's Avatar
Orlando, FL, USA
Car: 2001 New Beetle 1.8T GLX
Default Getting ECU upgraded, what should be double checked?
I have a 2001 1.8T Auto with 30,000 miles I am going to be getting APR software installed on. Given it's age I'm not sure what hoses and such I should double check to make sure they are in good shape, considering the extra boost pressure involved. Everything I can see look and feel okay to me, though I am inexperienced. The car has been garaged and is in pretty good shape in general, though the mass airflow sensor, and an engine coolant temperature sensor has had to be replaced.
Any tips?
Old 03-11-2007, 04:06 AM
SilverSportNOLA's Avatar
Faster Than Katrina
Formerly New Orleans, LA, USA
Car: 01 Sport
I don't think you will have too much to worry about, I did mine at around 40K .... have 77K now. You will more than likely burn out your clutch a little faster, but they don't seem to last all that well anyway.
Old 03-12-2007, 01:44 AM
NYBugman's Avatar
MkV Pilot
Brooklyn, NY,
Car: 08 CW GTI Pkg1 DSG
Vac lines, all clamps for the boost plumbing, condition of anything rubber that has to do with boost. Other than that there isn't anything you really have to check.
Be sure to change your trans fluid between 40K and 60K miles. VW's Lifetime ATF is not really lifetime. Whith more power comes more heat for the trans, so keep up on its maintenance.
WTT: Turbo s ECU with Neuspeed p chip for stock ECU. loseph Market Place Archives 2 12-03-2007 12:47 PM
WTT: Turbo s ECU with Neuspeed p chip for stock ECU. loseph Market Place Archives 13 09-27-2006 02:00 AM
What can be easily upgraded in a Beetle? JohnnyJet Car Audio 15 08-27-2006 10:12 PM
Anyone checked with AAMCO? mezonesxbox Transmission Talk 2 05-11-2006 01:34 AM
