Lemmiwinks, software “crack” for tuners.. - NewBeetle.org Forums
Old 04-03-2007, 03:52 AM
TechnoTrix'd's Avatar
Time 2 get my Bug on. ;-)
Brookhaven, PA, USA
Car: '01 NB TechnoBlue 1.8T GLX - Pepe Jr, 03 G35 - Diamond
Default Lemmiwinks, software “crack” for tuners..
OMG, this software is “DANGEROUS”!! Wow, what a nice drive I had earlier this evening after spending some time with the laptop and the Lemmiwinks software program.
For those with a VAG-COM serial cable you can download this free software created by REVO and make actual changes to your CPU's adaptation channels.
Here are a couple of the download sites:
Download Lemmiwinks Now from Ecodetuning
Download Lemmiwinks Now from Unixprohost
I am also adding a couple of great threads on other boards that have already explained in clear, no BS detail what this software is for and how to use it.
http://forums.fourtitude.com/zerothread?id=1618056
http://www.vwfixx.com/forums/index.php?showtopic=15329&st=0
Tonight I added some RPM’s to my idle to smooth out the vibrations from those VF Engineering mounts, and played with the fuel mix while on and off the throttle. Noticeable difference folks, almost feels like I “chipped” the car.
No kidding…
Take some time and read through these, then go out and have some fun..
TechnoTrix’d……..
Hey Click ME! – ToD 2K12 GTG & Cruise - - -ToD North East Bugavan Thread 2k12
Previously Owned Vdubs: '83 Blk GTI (Da' Bomb - moon-roof, ball shift knob, crazy striped interior), '87 Vanagon (Weekender - Brown), '90 Vanagon (Weekender - White, alloys, - one style'n refrigerator on wheels), '08 Graphite Blue Passat LUX.
Old 04-03-2007, 05:52 AM
bugasm99's Avatar
OG Stalker
Philadelphia, PA, USA
definately a good program to have. We have made some minor adjustments to my brothers s4 before. Just be careful and make sure you read everything before just messing around. You can hurt your car if you don't use common sense.
Old 04-03-2007, 07:15 AM
niki's Avatar
#1 Auntie
CA, USA
Car: Former owner of Bugzzi ('99 White GLS), new owner of '10 Civic LX-S
This is what I think of when I see Lemmiwinks:
If you ask for more patience do you think you'll simply get more patience?
No. You'll get an opportunity to be patient.
Old 04-03-2007, 02:55 PM
Billsbug's Avatar
Get in.Buckle Up.Hang on.
USA
No kidding…
TechnoTrix’d……..
I've known about this forever, but I've always wondered: Do u need to have REVO ECU software installed to use this?
wolfsbürgwe.:Rks
Originally Posted by gilligan
Old 04-03-2007, 02:58 PM
kaiser's Avatar
no longer use this site
torrington, CT, USA
Car: 01 techno blue t3/t4 big turbo
negative
sold the beetle, don't use the site anymore
Old 04-03-2007, 03:06 PM
Billsbug's Avatar
USA
Originally Posted by kaiser
negative
Cool, thx. I've heard the biggest 'benefits' are that u can up the rev limiter and remove the top speed limiter.
Old 04-03-2007, 03:12 PM
kaiser's Avatar
torrington, CT, USA
don't you have apr ? you shouldn't have a rev limiter.
Old 04-03-2007, 03:22 PM
Billsbug's Avatar
USA
Yeah, but this thread isn't about me or APR.
Actually I'm limited to 7200rpm now, APR always plays it safe...
Old 04-03-2007, 03:35 PM
bugasm99's Avatar
OG Stalker
Originally Posted by niki
Old 04-03-2007, 05:05 PM
CA Solt's Avatar
Freeland, PA, USA
Car: 2004 Platinum Gray: APR Stage 3+
Default Lemmiwinks
I've attempted tweeking w/Lemmiwinks a few years ago with the downloads from the 'tex, and I couldn't make the changes because I have APR upgrades.
My guess is it works w/ stock or REVO.
CA Solt
2004 GLS Platinum Gray
APR Stage 3+
305whp & 295 ft./lbs.
Saint Augustine - De Libero Arbitrio
- Unless you believe, you will not understand
Old 04-03-2007, 05:06 PM
Billsbug's Avatar
USA
Now that makes sense!
Old 04-03-2007, 05:28 PM
kaiser's Avatar
torrington, CT, USA
also works with giac and upsolute.
Old 04-03-2007, 05:57 PM
kcfoxie's Avatar
I'm not a girl. Sorry!
Durham, NC, USA
Car: 2003 New Beetle TDI
So basically it works with everything BUT APR... I'm glad they don't make TDI software. REVO for the win (followed by GIAC). I used this on my 2.0 to increase the idle, and up the timing a bit for mid-grade fuel, all said and done the car was noticably faster on acceleration and got a little better gas mileage. I opted for this over the GIAC 2.0L software chip.
Old 04-03-2007, 06:09 PM
kaiser's Avatar
torrington, CT, USA
i was under the impression that it would work on cars flashed with apr, but not work for cars with a chip from apr.
Old 04-03-2007, 06:16 PM
Brookhaven, PA, USA
This is basically what I did as well. Increased the on-throttle fuel load to 105%, decreased the off-throttle fuel load to 95%, decreased the crusing-throttle fuel load to 97%, upped the idle RPM's by 100, and advanced the timing by 2.25 degrees.
Expected outcomes are better power from the engine and better fuel economy. Nice bonus...
I have an APR chip sitting in a box at the house, but I may be putting the install of it off for a while. The old "butt" dyno is lov'n the changes I made.
I will have to take it to a real dyno to verify.
BTW, if you read through the VWFixx threads, it "say's" it works with APR (as well as GIAC, REVO, etc..), but it sounds like CA Solt has had a different experience.
So, if anyone else has played with this stuff, post-up!
TechnoTrix'd...
Formerly Hazard143
Connecticut,
Car: 2003.5 Blue Lagoon Color Concept, 84 GLI
Once I get a cheap laptop I will get vagcom/ V-tune and smooth out my APR "Pig Rich" 5000+ rpms. Im sure once I get that afr curve straight all he way through I will be able to pick up a few more horsepower and not get the backfiring when i shift.
AKA...Hazard143
www.dubsnorth.org
Matthew
Billsbug's Avatar
USA
Hmmmmmmmmm...
Old 04-03-2007, 06:20 PM
Brookhaven, PA, USA
Can't agree more with this statement from Josh! My neighbor is a long time gearhead and build's race-cars as a hobbie.
I consulted with him before I made any changes, and definately went very conservative for my initial tweeks. If you go crazy with some of these settings, you will destroy your engine. Period!
Until I can get some logs from VAG-COM, I am not going to take my tweeking any further.
Have fun......
Old 04-03-2007, 06:23 PM
Brookhaven, PA, USA
Hmmmmmmmmm...
That kind of makes sense, because the OEM programming is still there with the flash APR version. So the OEM adaptation channels would still be available and not locked down by the APR program..
Interesting......
Old 04-03-2007, 06:31 PM
Brookhaven, PA, USA
Hey Bill,
Actually, what it allows you to do is modify the adaptation channel #07 (Additive Offset To Speed Limiter) -128 kmh to + 127 kmh in 1km/h increments.
So, by adding km/h to this chanel, it in effect increases your rev limter accross all gears.
So, you could also do the opposite if you were going to give the car to a first time teenage driver. You could knock down the km/h's to prevent them from getting too stupid with it..
(Yeah, like we've never done that..........)
atp GTRS + software t0ad9 1.8 Liter Turbo 67 12-13-2008 09:04 PM
what software to use for my forum ? 1999 BEETLE 2.0 Liter Gas 4 09-30-2006 10:16 PM
What software is used for the front page? savethebluths.org Miscellaneous Hoo-Ha Archive 1 08-04-2006 10:56 AM
Shuttle foam crack puts launch in doubt PhoenixRising Miscellaneous Hoo-Ha Archive 1 07-03-2006 10:18 PM
What is the best photo shrinking software? EVZBUG Photography 10 12-12-2005 08:27 PM
