Alternator Replacement Experience - NewBeetle.org Forums
Old 06-13-2007, 08:38 PM
Exclamation Alternator Replacement Experience
Hi all!
I am just on here because I do some work on my fiances Turbo S.I use this forum and others to help work on her car as I am a WRX guy myself and VW's are weird to me.I just wanted to share my experience replacing the alternator to help others out.
1. Remove the battery negative. You don't want sparks flying.
2. Disconnect wires to alternator. There is one plug to undo and the power wire to remove.
3. Remove the tensioner pulley. Before you go unbolting it you need to release tension by pulling the tab towards you with a wrench then placing a nail or something to hold it open.
Just remove the 3 bolts.
4. Detach the alternator. Its just 2 bolts that hold it in place. It may take some wiggling to get it out though.
5. Getting it out of the engine bay. This is the part that had me cursing the "German Engineering in da Haus" Guy. Because of the NB tight engine bay there isn't enough room to pull it out. This is how I did it.
a. First remove the throttle body. Unplug it. remove air intake hose and vacuum line. then remove 4 allen wrench bolts. The openning is still not big enough so...........
b. Remove Bolts from the Passenger side motor mount.
c. Place jack under tranny and lift the engine until enough room is available to lift the alternator out. About 5-6 inches.
6. Installation is the reverse of removal.
7. When everything is back together do a Throttle Body Adjustment.
When I first started it up it made a loud banging or knocking noise at idle. It had trouble idling steady but revved just fine. Doing a little research found that a T.B.A. would fix it and should be done whenever the Battery is disconnected.
TBA procedure....
a. Pop the hood so you hear it working and know im not blowing smoke up your butt.
b. Open the driver side Door and don't touch any pedals.
c. Turn the key into the on position DO NOT START!!!!!
d. Go around to the front and hear the throttle body motor humming and clicking and be amazed at whats going on.
e. Take the key out of the ignition.
f. Your throttle body is adjusted and ready to go.
I know i had heard this type of noise before just not this bad. It is probably a good idea to do this every once in a while to keep running in tip top shape.I am not sure what models this works on I assume any Drive by wire 1.8T motor this case was a 2003 Turbo S
8. Enjoy your now running NB
Old 06-13-2007, 08:46 PM
Billsbug's Avatar
Get in.Buckle Up.Hang on.
USA
Nice How-To, thanks!
Next time however, TAKE PICS!
wolfsbürgwe.:Rks
Originally Posted by gilligan
Old 06-13-2007, 08:51 PM
I just wanted to give back a little. I would have taken Pictures if I knew it was such a pain in the arse to do
Old 06-13-2007, 08:59 PM
Billsbug's Avatar
USA
Hey, PITA is the New Beetle's middle name!
Old 06-22-2007, 02:49 AM
nickthehick78's Avatar
A bug named sue
vernon, CT, USA
Car: 2002 New Beetle Turbo S
Default hey
hey i just changed my alt, what a pain. i dident remove the motor mount. did everything you said but after i removed my throttle body i took the 2 bolts off my fuel rail and pulled it and all 4 injectors out, had just enguff room to get the alt out. just my 2 cents incase someone wants to try it this way.
Check out Sue's very own web page at WWW.MYSPACE.COM/ABUGNAMEDSUE 2002 New Beetle Turbo S, Platinum Metallic Grey. APR 93 oct/100 oct/stock chip. APR 3" turbo back exhaust,APR R1 diverter valve,ECS "race" n75 valve.ECS big brake kit(12.3")slotted and cross drilled rotors, Bilstine coilovers. 42dd led interor light kit.
Old 03-05-2010, 12:15 PM
Old post resurrection
So it there a trick to loosing the alternator once the bolts are removed? it is a pain
Old 03-05-2010, 12:24 PM
A bug named sue
vernon, CT, USA
wiggle, wiggle, wiggle. back and fourth, up and down. i belive i used a big screw driver or a pry bar to help me. it was very tight. be carefull what you pry on! putting the new one on is tight also, once you get mad and call it names and pull as hard as you can, then give up. it will fall right off. haha. goodluck!
Old 03-05-2010, 09:54 PM
of to a-wigglin I go!
Thanks for the quick response.
Old 03-12-2010, 01:52 PM
FastAndFurious's Avatar
Same Name, New Parts
Staten Island, NY, USA
Car: 99 BMP 1.8BT on air
You dont need to remove the throttle body or the motor mount to get the alternator in and out on a 1.8T.
I've done it several times through the headlight.
Just remove passanger headlight and headlight cup, and disconnect the throttle body hose, plenty of room to get it out.
Reason i do it this way because when you remove the throttle body, you need to change the gasket and do TBA.
http://forums.vwvortex.com/zerothread?id=3914840
Old 05-10-2010, 11:32 AM
Thanks, I'm struggling with this one too! I have the bolts removed holding the alternator on but cant seem to budge it. The bolts are attached to sleeves that seem to be holding the alternator in. Can the sleeves be driven out? Or should I just keep wiggling?
And I was wondering how to get it out of the car! I'll see if I can remove the passenger headlight but that's probably shot. Maybe if I remove the whole passenger fender?
Old 05-10-2010, 02:14 PM
you dont need to remove the passanger fender, it will not help at all.
just remove the headlight and headlight cup thats holds the headlight in place. then you have plenty of room to get it out
Old 05-10-2010, 04:26 PM
Thanks, I'll give that a try if I can work the part loose. Sounds better than taking the whole nose off!
Old 05-11-2010, 02:34 AM
I used a some PB blaster, squirted some in the bolt holes then gingerly pryed the alternator loose with a screwdriver. A little prying, a little wiggling by hand and it FINALLY came free.
Old 05-11-2010, 10:44 AM
OK, I got the alternator free. The picture above shows where the top bolt threads in. I was able to take a tire iron and pry the top of the alt forward off of that mount. Then I could wiggle and twist it to get the bottom part of the bracket free.
Looks like my passenger headlight is in OK shape, so I'll see if I can get that off and remove the alternator that way.
Thanks all!
Old 05-12-2010, 01:29 AM
[url=http://forums.vwvortex.com/zerothread?id=3914840
vortex media group[/url]
Yes, that does work well! I vote we call this maneuver the "F-and-F-Section"
Old 05-13-2010, 03:35 PM
Well thanks for clarifying that! A lot of people dont belive it could be taken out the headlight and much easier too.
Old 05-15-2010, 03:39 PM
It also helps to get at the belt and all - it was certainly easier to put all that back together with the headlight out!
Old 10-28-2010, 11:18 PM
Thanks for the "through the headlight hole" info. Also wanted to add I had to remove the screws holding the front of the innner fender to get to the 10mm (socket size)nut on one of the headlight bucket screws and that you do not have to remove the 8mm headed screws that hold the headlight lock in the bucket. I did have to compress the top of the bucket a little to get it out. I turned the alt where the mounting holes are up to get it out. The shop where I took it is charging me $100.00 to rebuild. It would have been another 100.00 to Remove & Reinstall it. His book allowed 1.6 hrs. It took me 1.5hrs to get it out. That includes cussing and 15 trips to my tool box. I still made about $65.00/hr.
Had quite a N.B. experience today! Beetlebomb The New Beetle Experience 14 02-21-2007 07:28 PM
WTB: replacement clasp or replacement armrest lid FineExampl Market Place Archives 2 08-11-2006 04:00 AM
Dealership experience CoriBug 1.9 Liter TDI 22 03-21-2006 09:23 AM
My best experience became a nightmare jitsion The New Beetle Experience 6 12-12-2005 02:24 AM
Has anyone experience this with their NB? Crazy_MoFo Questions, Issues, Concerns, or Problems with the New Beetle 3 10-06-2005 03:50 AM
