no start, 2001 turbo beetle - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > 1998-2011 New Beetle > 1.8 Liter Turbo
Old 08-14-2007, 09:47 PM
Default no start, 2001 turbo beetle
car died. blown fuel pump fuse. blew several more with no start. now fuse does not blow, but several warning lights stay on when you crank. starts, and immediately dies. any thoughts? any ways to diagnose fuel delivery, etc with no special scanners or stuff? thanks
in tulsa, ok
very hot
Old 08-15-2007, 12:19 AM
Lnzbug's Avatar
Arlington Heights, IL, USA
Car: 2012 Beetle+ 2001 blue vortex 1.8t + 1971 vert + 68 bug & 71 & 78 buses
Your timing belt is ok?? Maybe the impellers went on the water pump. Just a guess
Old 08-15-2007, 12:58 AM
cyberbeetle's Avatar
Hudson/Spring Hill, FL,
Car: Toyota Prius
You would need to check fuel pressure with a gauge, maybe the fuel pump is shorting itself out.
Old 08-15-2007, 02:07 AM
Default t-belt, w-pump both good
hmm...
Old 08-15-2007, 02:47 AM
SilverSportNOLA's Avatar
Faster Than Katrina
Formerly New Orleans, LA, USA
Car: 01 Sport
Now that it no longer blows the fuse, Do you hear the fuel pump prime when you open the drivers door. Get under the car on the passenger rear side and have someone open the drivers door and listen for it, unless it is in a quite space where you can hear it from the other side. As for checking, you will need to get a fuel pressure gauge kit ... I think HarborFreight has them for a decent price. I am not sure where to check it on our cars .... but when you are ready I am sure we can look it up in our bentleys.
Old 08-15-2007, 12:56 PM
Lnzbug's Avatar
That only works once after the car has been sitting for a good long while. It doesn't prime everytime.
Had you just gotten gas at a station that was having their tanks filled? Could be the fuel line (filter) got clogged. I'd look at the one under the door just in case.
Old 08-16-2007, 09:55 PM
Default update, still no start, puzzle gets more tricky
pulled wires off fuel pump
only getting 3 volts, only getting barely a trickle of fuel out fuel preee line under hood.
replaced fuel pump relay.
still only getting 3 volts.
any ideas? it did blow a coulpe fuel pump fuses prior to not blowing them...pump will run to prime, but at specs mentioned...3 v and low flow.
this is puzzling to me, pls help.
Old 08-17-2007, 01:19 AM
Faster Than Katrina
Car: 01 Sport
Fuses blowing is usually a dead short. Not sure why they are not still blowing ... check for frayed wires, make sure you are getting the correct voltage to the relay, and if so, check for resistance between the relay and the pump. You might also check your ground ... make sure the vehicle is grounded well and all ground wires for fuel pump and other accessories are connected to the body well.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
2001 Turbo Beetle Auto 39,667 $9,500 periwinkle Market Place Archives 13 07-15-2007 01:34 AM
2001 Volkswagen New Beetle - 2 Dr GLX 1.8T Turbo Hatchback Sport bianchef Market Place Archives 4 05-16-2007 11:20 PM
2001 TURBO Beetle for sale! n0b0dy The Canada Corner 3 12-11-2006 05:59 AM
2001 New Beetle won't start flashing idiot lights puzzlin Questions, Issues, Concerns, or Problems with the New Beetle 9 02-10-2006 04:24 PM
