you can soak the bolts with some WD-40 drive the car get the stuff hot under there and and jack her up... the WD will absorb into the cracks and stuff and itll make it easier... the studs might be a pain in the but and pulling the manifold off would be a little bit of a hassle.
WD-40 them the night before you need them off. Same problem here but I soaked them good. If you really want to break them off, use an impact wrench. That'll either break them or get them loose. DO use new copper locking nuts. Regular steel nuts will come off since they do not expand and contract well with heat. Made that mistake on the air-cooled engine.
When doing this turbo removal, don't make extra work. It took about a day to do my OEM turbo removal and install. Thats taking my time and having torqued everything to spec. Can't forget about doing it in a cold garage.. on the floor with only car ramps.
2001 Beetle 1.8 for the straight roads. 1973 Porsche 914 for the curves. |
Use "PB Blaster" (found at O'Reilly Auto parts and Advance, I believe). It's in a spray can with red and yellow writing all over it. It's some of the best stuff I've ever used...
I also ordered new nuts, bolts, and gasket from the dealer. The bolts come out of the turbo with vice grips pretty easy. |
that pb'laster is good stuff should work well
always go back with new hardware and dont worry the turbo should be fine ,unless you jam the socket through it anyway good luck hope it turns out well and by the way nyum96 good selection of vehicles i have the same things a red '73 914 and a red '01 new beetle both 1.8 with 5 speed GOOD STUFF!! |
| sub-frame bolts | CaL | Technical Modifications | 5 | 06-11-2007 02:02 PM |
| Sub-frame bolts... | Silverbullet007 | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 04-16-2007 04:18 AM |
| airbox cover bolts | basskleff | 1.9 Liter TDI | 3 | 03-25-2007 05:31 AM |
| Stretch bolts... reuse them? | BozemanboB | 2.0 Liter Gas | 4 | 04-02-2006 04:31 PM |
| Stretch Bolts | Ouphe | 2.0 Liter Gas | 8 | 01-20-2006 12:05 PM |
