Timing Belt Tensioner reuse - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > 1998-2011 New Beetle > 1.8 Liter Turbo
Old 09-23-2007, 07:02 PM
Mr_Eddy's Avatar
Cedar Rapids, IA, USA
Car: 2012 Beetle 2.0T, 2011 Golf 2.5
Default Timing Belt Tensioner reuse
OK, before I start this, I know that I was an idiot (yes, I'm admitting it, so go easy on me), but I changed the timing belt a few weeks ago, and to save a bit of time and money, I didn't change the water pump.
Only took me about six hours to swap out the belts and tensioners. Thought it went pretty good.
Now, about 2500 miles later, it appears the water pump has failed. Temperature light blinking red. Fans are running, coolant level is fine. I know, it could be the thermostat, but with a plastic implellerÖ So I get to rip everything apart again.
Question is this. Can the belt tensioner be reused? (yes, I did replace that) The reason I ask is I was messing around with the one I took off and I was not able to press in on the piston. This made me wonder if it was just jammed or are they a ratcheting device that cannot be pushed back in? Iím hoping I can just jam the grenade pin back in as Iím removing everything, but I need to make sure because I want to order parts today.
Also, how much G12 will I need to refill the system?
Thanks
Ed
As quoted from my 12 year old daughter (she's 21 now) in class one day...
"If life gives you lemons, make Lemonade
But if life gives you limes, make Margaritas"
I have no idea where she got that idea from
Old 09-24-2007, 12:53 PM
noR's Avatar
noRRegistered Member noR is offline
Jackson, MS, USA
It's possible, makes it pretty darn hard, but it's possible I think.
noR | me | Phrog
PHROG
Old 09-24-2007, 05:47 PM
as far as i know you can use the same tensioner as long as the tensioner isn't loose....if you can push the tensioner in and slide a pin in it then that means the tensioner is no good... what you might have to do is put the tensioner in between vice and that should push it back in....when your turning the vice do it slowly so you dont break the tensioner........
Old 09-24-2007, 05:48 PM
OH, USA
Car: 03 GTI
It's possible--when it is on the car with the pulley there too. There is a slot in the middle of the pulley's support frame near the tensioner/a place to thread in a specialized tool for collapsing the piston in the tensioner. A fully threaded bolt/threaded rod, nut and washer can also be used. The threaded hole is in the very top of tensioner. I saw the procedure in a Bentley manual when I did my TB & WP job.
Old 09-25-2007, 03:39 AM
'01vwbeetle's Avatar
I gots a new dub!!
Maysville, OK, USA
Car: 2003 VW Jetta
Originally Posted by Mr_Eddy
....Also, how much G12 will I need to refill the system?
Thanks
Ed
You will only need 1 gallon, if you buy it buy the gallon. It will have to be mixed 50/50 with distilled water. The 1.8t holds a total of 5 liters.
2001 VW Beetle GLX aka Sasha. She will be missed!! She is gone but not forgotton!!
Old 09-25-2007, 04:50 AM
NBTurboFreak's Avatar
20V GTRS
Car: 2001 Sliver Arrow GLX
Piczo Pics -- WoW
2012 Tiguan S 5-speed candy white (new daily)
2013 Beetle Turbo DSG (sun and sound) reef blue
Old 09-25-2007, 05:54 PM
Mr_Eddy's Avatar
Thanks all, got the pump, thermostat and 3 liters of G12 on order. Should be here tomorrow.
The tip about the pulley slot and threaded hole on the tensioner should prove especially useful as it is a new tensioner.
I'll tear into again Saturday.
Ed
Old 09-30-2007, 10:21 PM
Mr_Eddy's Avatar
I'm not sure, but I think it was the pump that was causing the overheating.
Hardest part was getting the alternator off to swap the thermostat. I had the pump out in about two hours.
The tip about the pulley slot and threaded hole in the tensioner worked great. I use a 5mm x 40mm bolt with a couple washers under the head to keep it from slipping through the slot. I was going to try and take a picture, but just forgot.
So Sluggo's back up and running.
Feel free to refer to this thread if anybody ever asks, "Is it really necessary to change the water pump when I change the timing belt?"
Thanks All
Ed
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
timing belt tensioner 40k branvan 2.0 Liter Gas 4 05-25-2007 10:08 PM
Timing Belt Tensioner Removal Question GLXpress 1.8 Liter Turbo 1 06-12-2006 08:23 PM
Get rid of the hydraulic tensioner (timing belt) Buggin 1.8 Liter Turbo 3 03-21-2006 04:59 AM
toothed belt tensioner sequoiagrapeboy 2.0 Liter Gas 1 01-27-2006 11:20 PM
belt tensioner tonysailor 1.9 Liter TDI 2 01-24-2006 07:50 PM
