new Upgrades, please help - NewBeetle.org Forums
Old 12-14-2007, 06:01 AM
Default new Upgrades, please help
Hiya
Wondering if u guys could help me for a bit here, deciding if this would be a good decision to upgrade my turbo, without alot of other things id have to get...for an 03 TurboS beetle.
This turbo, will it fir Bolt on?
http://www.20squared.com/catalog/pro...15fc3b9caa9624
This inlet pipe..
And these new set op boost hoses.
I just want to make sure, everything will fit, and I wont have to be spending some extra $$ on something i didnt plan to..
I do have revo Stage 1, upgraded DV and I have a 3Bar and 4Bar FPR.What else would I roughly need to change so that turbo can run smoothly?
Thanks in advance.
Old 12-14-2007, 06:14 AM
yelojkt's Avatar
beetle driver for life
Wichita, KS, USA
Yeah the K04-001 is a direct bolt-on. I believe (95%) the intake pipe will work. And it looks like the boost hose kit should work. To get the full effect of the K04 or even your K03s with the REVO stg I you should put on a 2.5" exhaust and DP with a full flow cat.
Moded to make driver grin.
Did You see Yelojkt?
Dyno Video before custom K03S
09 ZX6R Candy Blue
Old 12-14-2007, 06:19 AM
any suggestions from where can i buy the DP, cause I have a local shop than can make the exhaust, but, i want to purchase the DP already made, just to avoid weird stuff with the sensors.
Old 12-14-2007, 01:58 PM
noR's Avatar
Administrator
Jackson, MS, USA
http://www.techtonicstuning.com/
noR | me | Phrog
PHROG
Old 12-14-2007, 04:42 PM
Back yard, MD,
Car: 02 1,8T NB
Originally Posted by noR
Go to www.gprparts.com is the same parts and cheaper.
It's not a car, it's Volkswagen.
Driver wanted.
Old 12-14-2007, 05:40 PM
alright, ive ordered those 3 items, now, do I need to change the settings of REVO? or should I just leave it like that?
And, what spring colo should I use? I think i have the green one on.
Old 12-14-2007, 09:25 PM
yelojkt's Avatar
Wichita, KS, USA
You should call your REVO dealer to find the answer to the first question. You could also have it dynoed and have them check your air/fuel ratio. I have no idea on the spring I have not experimented with mine yet.
Old 12-14-2007, 10:08 PM
v-dubed's Avatar
my turbo is bigger!!!!!!!
crap hole royse city , TX, USA
Car: 02 black sport
ko4 is really not worth the time or effort.... u can pull the same numbers with the wastegate mod... id go gt28 or 28rs for screwing around...
03 evo vIII 2.3 gt35rhta...
93 eagle talon awd gt42
91 talon gt35r dd
08 cbr1000rr
1000hp club!!!
Old 12-15-2007, 02:58 PM
talked to these guys, and this is what I am getting, they also said the k04 isnt worth. I believe some extra $$ and get the max out of it...they said Ill just need imporved injectors, and they recommend to change the manifold.
http://ecodetuning.com/shop/cart.php...t_detail&p=555
Old 12-15-2007, 03:30 PM
v-dubed's Avatar
Car: 02 black sport
stay away from the eliminators... if ur gonna go to a bigger turbo...go to a true gt28rs... 440+ injectors, adj fpr,255lh fuel pump, and a 3 inch maf, and prolly uni software
Old 12-16-2007, 01:00 AM
aight, so, if I buy this, will this be bolt on the stock manifold?
I already have the FPR and the software. And im aware of the injectors. New thing is the fuel pump.But, its ok...
what else would i need to mount that baby up?
Turbo upgrades skariader 1.8 Liter Turbo 2 10-23-2007 02:22 AM
upgrades robpad 1.8 Liter Turbo 3 09-24-2007 01:42 PM
I Want/Need Performance Upgrades supercasper 2.0 Liter Gas 23 09-16-2006 04:48 PM
Performance upgrades TDI Kid410 1.9 Liter TDI 2 08-16-2006 02:12 AM
performance upgrades roadkingdoc 1.8 Liter Turbo 8 06-20-2006 12:33 PM
