Do what I do, shift at redline!
![]() Most people shift and cruise at around 3000-4000rpm, so use that as a guideline. BTW, do u have the OEM in-dash CD stereo or is it cassette??
wolfsbürgwe.:Rks Quote:
No. Previous owner spent about $7000.00 for total Alpine,
IVA D300 with CD, DVD, 12 CD remote, GPS, Blue tooth Cell set up and hugh woofer under spare tire. Try figuring out all that. No CD to program GPS tho. I heard they cost about $500 bucks. Thanks for response. |
The difference in the 5 and 6 speed tranny gearing is amazing. My 2nd gear redlines at 65 mph, 3rd gear redlines at 102 mph, so I don't use 4th til I'm at at least 80 mph, 5th is for 90+ cruising on the highway only.
Appreciate all the threads. I just refilled my tank for first time. 28MPG. Manual says ok to run 6th gear at low RPM. So I have been running mostly town trips in 5th and 6th, around 2000RPM. I miss a lot of 3rd and 4th shifts. 2004 1.8 turbo 21000 miles. What do you think?:
My car would bog if I had it in 6th at 40.
She never gets into 6th until 60. I shift at 3,000, or more if passing.
Former VWs: 2002 NB Turbo S - Platinum Gray 2003 NB TDI - Galactic Blue 2005 NBC 1.8T- Tornado Red 2006 Passat 2.0T- Blue Graphite 2003 NB Turbo S - UniRed 2005 V6 Touareg V6 - Campanella White Currently: 2002 NB GLX 1.8T - White Paint |
I really don't understand your fixation with the low rpm's, is it to save a few $ on gas? The lower u run the rpm's, when u need to accelerate, the faster u'll burn up the crappy OEM clutch.
Not really Bill. As long as the clutch isn't slipping already, accelerating from low rpms shouldn't make it slip.
I'd shift at 4K when passing, 3K for daily driving. And for top acceleration I believe you want to shift at about 5, 5.25K for all but 1st gear, 1st you'd run up to redline. |
When I'm around town.....I get into 6th on occasion....but mainly only on the highway....
My Beetle Gina http://www.newbeetle.org/forums/showthread.php?t=24586 2002 Beetle Turbo S Platinum Gray Metallic That's about it! ![]() __________________________________________________ _ Previous VWs Owned 1985 GTI, 1969 Bug |
The low gears are where the torque's at - at least in my 5spd... Can the 6spd be THAT different? Or maybe our ideas of performance are different Could you clarify? This has been bugging me
The Six Speed is very close ratio......but the engine has alot of power, so even if I'm cruising in 6th and need to pass.....I push down the pedal and it just goes! The get up and go is just amazing.....5th & 6th are considered final drives.....but they don't feel like it when you need to get going
but to be on topic i shift at 4k or so for DD
my perception may be swayed because of the type of driving i do... i prefer coasting and highway to the local traffic. |
I remembered reading this a while ago, but if you want to optimize your shifts points, I think this guy has done the math.
http://forums.vwvortex.com/zerothread?id=3580757 Later...
Motown ~ 2004 Cyber Green NB. CONVT. 1.8T APR Tuned / APR R1 / New South Performace / Silicone Boost / N75 / K&N / Samco TIP-Hose Kit / GPA / 20% Tint / Cactus Mrs. Motown ~ 2005 Passat GLS 1.8T APR Tuned / APR R1 / N75 / 35% Tint |
| FS: HPA Short Shift Kit (Turbo S 6 Speed) | r0nd3L | Market Place Archives | 2 | 02-21-2007 01:13 AM |
| Shift points | Beetlebomb | 2.0 Liter Gas | 13 | 01-28-2006 03:51 PM |
| Scraping sound at shift points(?) | Beetlebomb | 2.0 Liter Gas | 2 | 01-06-2006 03:25 AM |
| Grounding points | kenship | 2.0 Liter Gas | 0 | 01-03-2006 06:02 PM |
