temp sensor hose adaptor - NewBeetle.org Forums
Old 01-13-2008, 03:25 PM
Beetle Pusher
Meshoppen, PA, USA
Car: 00 GLX 1.8T, 01 Mustang Bullitt edition GT,90 Mustang GT, 07 Hemi Ram QC
Default temp sensor hose adaptor
When I installed my gauges last year I never installed the adapter for the temp sensor because just before the gauge purchase from 42DD I did the timing belt/water pump replacement. Since the coolant was new i figured i'd give it a year b4 I replaced it. Now i was wondering if the upper hose could be removed on a cold engine without having to drain the whole cooling system? Anyone done this recently? Should I just follow 44dd's instructions and drain then install adapter?
thanks
98 NB GLS Tekno Blue 5 Speed ///SOLD/////
MEGAN Racing 2.5" ss catback
20% tint
*and it's still slow
00 NB GLX Tekno Blue 5 Speed
MEGAN Racing 2.5" catback
Snowbox-ectomy
A-pilar 2 gauge pod
Stewart-Warner silver face- boost/h2o temp
Neuspeed P-Flo
DENSO IRIDIUM's
ECS Poly Dogbone Mount
Old 01-13-2008, 05:29 PM
CGK's Avatar
Beetleman
Salisbury, NC, USA
No need to drain the system.
When I installed mine I just disconnected the top hose from the radiator, cut the necessary amount off, slipped the adapter on and reconnected to the radiator.
On a cold engine, most of the coolant is in the radiator anyway and there is very little left in the top hose.
You'll have a little run out but you certainly don't need to drain the whole system.
Good luck with install!
Old 01-14-2008, 10:38 PM
Beetle Pusher
Meshoppen, PA, USA
thanks
thats what i thought^ Did you bleed the air out with the coolant cap open??
Where is my temp sensor?? doyal 1.9 Liter TDI 5 07-28-2007 07:15 PM
Temp Sensor Replacement Help aefbug Questions, Issues, Concerns, or Problems with the New Beetle 5 02-27-2007 04:01 AM
Outside Air Temp sensor jc918t 1.8 Liter Turbo 7 11-19-2006 08:18 PM
Outside temp sensor nippywiffle Questions, Issues, Concerns, or Problems with the New Beetle 4 11-01-2006 05:12 PM
Coolant Temp Sensor GaUdeNtiUs 2.0 Liter Gas 8 02-09-2006 10:14 PM
