most effective intake? - NewBeetle.org Forums
Old 02-04-2008, 03:55 AM
"that kid with the bug"
orange city , FL, USA
Car: 2003 new beetle Turbo S and just sold my baby "the beast" a 1970 baja bug i built from the ground up
Default most effective intake?
ok, looking for an intake. im about to make a simulated CAI using the stock shaved airbox, a K&N, and some 3.5 inch PVC. but, i want to get another intake later on iin life. does anyone have any dyno numbers from diferent intakes? i dont want to loose any low-end power, id actually like to gain some. i dont want to get hear-say answeres, just cold hard facts.
Matt
Old 02-04-2008, 04:45 AM
afinley's Avatar
Cold Buggin'
Raleigh, NC, USA
Car: 04 black BTS
on a turbo car you dont lose any power by opening up either end. on an NA car there are pulses on both the intake and the exhaust, but on our cars the turbo does all the work.
Unitronic Stage 1+, 3" DP, Venair TIP, Forge 007, Venair Boost Hoses, Swiss Airbox, "Free Flowing" MAF.
25 psi of fury.
Old 02-04-2008, 01:11 PM
you gain colder intake temps(by a small ammount) and better throttle response, im wondering what intake performs the best.
Matt
Old 02-04-2008, 03:41 PM
Billsbug's Avatar
Get in.Buckle Up.Hang on.
USA
I just installed an RSD dry filter CAI from www.tmtuning.com .
You can't really see anything on a dyno, cuz u'd need a specialized forced air source to show any results. I coincidentally met the local rep for tmtuning one day at the shop I use, they used such a system to develop it in Germany, it was originally created for the Audi TT: "Turbo engines stock will see a minimum 8 to 10 horsepower increase."
It's amazing, the sound is totally whack, like a loud, ghostly, metallic cough, u can even hear it clearly if u just blip the throttle, pedal response at all speeds is improved, there's no loss at the lower end, if anything it pulls away faster, but u really feel the 'oomph' at higher speeds.
wolfsbürgwe.:Rks
Originally Posted by gilligan
Old 02-04-2008, 03:51 PM
Billsbug's Avatar
USA
This company is very popular with Audi too: http://www.modshack.info/TTDA.htm
Old 02-05-2008, 03:33 AM
i like the look of yours bill! its prety cheap too! i think ill go with that one. is it the maxflow one?
Matt
Old 02-05-2008, 01:14 PM
Billsbug's Avatar
USA
Matt
RSD mod. MaxxFlow kit, small, 60-75 mm neck dia., US $ 129.00/set order no.: RSD-1010
Important! This CAI is not recommended for areas with dusty conditions. This a dry foam element CAI, dusty condition areas should use an oiled filter.
I had mine painted, painting with a clear coat really helps reflect heat. BTW, the walls are too thin to powdercoat without jeopardizing the structural integrity of the aluminum. U'll need to get 5' of aircraft quality tubing and I bought new clamps, the ones they give you are lousy quality.
Old 02-05-2008, 01:49 PM
Yurko's Avatar
blark.
Omaha, NE, USA
Car: 2000 GLX 1.8T
I was reading something on the 'tex the other day about how intakes with velocity stacks are the best way to go if the filter is sitting in the engine bay (i.e. not a true CAI). I do know that K&N makes a cone filter with a 3" outlet and a volocity stack built into the inside.
That being said the consensus on the 'tex also seems to be that a stock turbo won't benefit much over and above the stock airbox with a K&N filter.
Old 02-05-2008, 02:09 PM
Billsbug's Avatar
USA
By 'stock turbo' do u mean an unchipped KO3/K03S? I can tell u this RSI CAI is the business, at least on a chipped car.
Old 02-05-2008, 03:08 PM
well i live in florida, not too dusty here. maby K&N makes a filter that will fit in the housing?
Matt
Matt
Old 02-05-2008, 03:14 PM
Billsbug's Avatar
USA
Matt
Well, yeah, of course (panel filter): http://www.autotech.com/prod_engine_knair.htm
U live in south Florida?
Old 02-05-2008, 03:19 PM
noR's Avatar
Administrator
Jackson, MS, USA
Fill in your profile for us mat3833.
What sort of bug do you have, and what's your climate?
It's helpful info for anyone regarding performance suggestions.
noR | me | Phrog
PHROG
Old 02-06-2008, 03:26 AM
oops, i ment to do that! im in central florida. a smallish city called orange city. its a turbo S 2003 model in reflex silver with about 43000 miles on it.
Matt
Old 02-06-2008, 10:55 AM
Yurko's Avatar
blark.
Omaha, NE, USA
Car: 2000 GLX 1.8T
yeah, exactly. my understanding is that you don't see the benefits from the intake until you're chipped.
Old 02-06-2008, 12:23 PM
what is the RSI CAI?? i cant find it anywhere...
Matt
Old 02-06-2008, 03:12 PM
Billsbug's Avatar
USA
Matt
RSD MaxxFlow CAI, not 'RSI CAI', click on 'Engine' here and u'll see a thumbnail for it: http://www.tmtuning.com/vw .
Old 02-06-2008, 03:19 PM
Billsbug's Avatar
USA
Interesting, maybe it's a function of increased boost?
Old 02-06-2008, 04:21 PM
well in theory, any inprovment in the intake will show gains. it may not be in peak power but there will be gains. think about it, can you run a mile with a straw as your breathing hole? if you can kudos to you, you could also probobly suck a golf ball through a garden hose. but the more air the engine has available the more efficent it CAN be. an engine is just a big pump. if you give your lawnmower more air even it will make more power.
Matt
Old 02-07-2008, 12:08 PM
Yurko's Avatar
blark.
Omaha, NE, USA
Car: 2000 GLX 1.8T
Matt
I'm not saying that a different intake won't make a difference, but from an ROI standpoint you will get more bang for your buck if you're chipped IMHO.
between the options of a new intake, a new exhaust, and chipping, it seems like the new intake is last on the list in terms of potential benefit, largely because you'll see more of a power gain if the other two are already there.
see the 1.8T stock turbo tuning guide for a little more info
cold air intake vs ram air intake xXRockyHorrorsXx Styling Modifications 33 09-03-2007 08:55 AM
air intake how to? SALTYDOG1960 1.8 Liter Turbo 55 04-18-2007 11:46 PM
Intake? PrecisionDrummer 2.0 Liter Gas 7 03-18-2007 10:07 PM
air intake montague 1.8 Liter Turbo 2 08-10-2006 03:49 AM
Fujita Intake FineExampl 2.0 Liter Gas 10 03-18-2006 04:00 PM
