If I had a vag com I would post the results. All I have is a cheesy little scanner from auto zone.
Before it popped the CEL the first time it would stumble upon start up first thing in the moring when it was cold. After that it was fine. No stumble at all and no noticed loss of power. |
P0400 looks like an EGR code to me. What year is your car? Possible that your egr valve is stuck open and causing it to run badly. the P0310 is a wierd code. Dont remember seeing that one ever before. It means missfire on cyl #10 on dodge and fords with 10 cyl engines. Your generic scan tool might be lying to you.
EGR...... Hmmmmmm That thought has come across my mind. Wonder if that thing is easy to get to, and what the damage would be on a new one.
Oh yeah Wasabi is a 01 1.8 with 55,000 on her. #10 cyl.! Oh I wish I had 10 cylinders in my Buggy! ![]() |
if you're getting an SAI code on cold mornings it means either your SAI pump is going out or you have a leak in one of the tubes. it's not a performance issue, just emissions, and one solution is to remove it altogether. If it is malfunctioning the other code could be an O2 sensor.
I know what you mean about the code reader. I wish I had the dough to throw down for a lappy and vag com software. Or even someone in this neck of the woods that has one.
I'll dig through the bentley and see if I can come up with anything there. I thought I saw an egr or something resembling one on the left side of the head (in between the head and airbox)? Ah but I could be wrong. I just hope it's not something that will affect the pocketbook to much. Isn't the EGR also refered to as the "kombi valve" also? |
| What do these codes mean? | BeetleCamry | 2.0 Liter Gas | 9 | 08-10-2007 02:21 AM |
| Codes | funky | 1.8 Liter Turbo | 7 | 07-08-2007 12:02 AM |
| Need Help 2 codes | Warnberg | 2.0 Liter Gas | 3 | 07-07-2007 03:23 PM |
| need help with codes | bobaganoosh | 1.8 Liter Turbo | 6 | 12-30-2006 04:50 AM |
| e-codes | tjd | Technical Modifications | 0 | 01-20-2006 10:30 PM |
