Understand that unplugging sensors/parts such as the MAF sensor for diagnostic purposes on this car will not give any clues or tell you what the source of the problem is, these cars have redundant backup's.
When you unplug something like the MAF sensor, the ECU will simply throw a code and redirect how/where it gets the needed information, the car will usually still run but differently and through other means, this is why the old school "disconnect" method of diagnostics normally does not work on OBDII cars like this one. Working on these cars and running diagnostics here requires a vagcom or scan tool, there is no getting around it.
Battery change-out forced me to take the cover off the battery, and one of the connections inside came loose without my noticing. I think the connector (2" wide, three wires?, right side) may be a dedicated connection for ABS. Either way, the wires for it got wrapped around the rear upright bracket and when I shut the lid, it pulled off the connector. I have no "idiot" lights any longer ![]() |
folks get a Vag-Com, or a simple scan tool... it really is your friend...
turbo lag n. The period of time between owning a 2.0 VW and trading up to a 1.8T...
This situation should be treated somewhat like one of those miniature spare tires, temporary, the car should not be driven in this condition for an extended period of time or further damage/problems could result. On a 70 Plymouth Road Runner with a big block V8, you can unplug various components as a method of diagnostics, often you will be able to determine what has failed or in not functioning up to par by following this procedure, this rarely works on newer vehicles for the reasons I have mentioned. In the case of a MAF sensor, a dealer technician might do one or both of the following to determine whether or not an MAF sensor is bad: 1. Connect the vehicle to a vagcom and analyze the readings. 2. Temporarily install another MAF sensor that is known to be good, then proceed from there with his/her diagnostic. |
| ECP and ASR light help please.. | milton | 1.8 Liter Turbo | 1 | 11-27-2007 09:31 PM |
| ASR issue... | fohveh | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 03-02-2007 01:03 AM |
| What helps you cope? | JenBug | Miscellaneous Hoo-Ha Archive | 27 | 02-02-2007 12:11 AM |
| Running ROUGH!!!!!!(sort of) | SeeMKay | New Beetle Convertible | 2 | 03-01-2006 04:36 PM |
| ASR light blinks when shifting????? | 01GLXTURBO | 1.8 Liter Turbo | 13 | 01-15-2006 06:19 AM |
