Secondary air intake hose - NewBeetle.org Forums
Old 02-13-2008, 03:04 PM
Lnzbug's Avatar
MINI & NB FOR LIFE!
Arlington Heights, IL, USA
Default Secondary air intake hose
Ok, I'm sick of seeing the friggin CEL. I bought the hose now what? The pic points to the hose I got. Is it something I can do without John helping? Should I wait till it's warmer so I don't snap off parts installing it? How long will it take to do? Help me please.
Old 02-13-2008, 03:18 PM
noR's Avatar
Administrator
Jackson, MS, USA
I can actually see both ends of the hose in your photo there.
So that's how easy it is to get to.
I dunno how cold it is for you, but I'd try it now. (40+*F here)
That weird clip thing in the middle might be a pain; but you could just as well leave the old one in place and use it, rather than try to pry it out and putt he new one in. The problem is the hose, not the clip that's holding the hose.
noR | me | Phrog
PHROG
Old 02-13-2008, 03:21 PM
Lnzbug's Avatar
MINI & NB FOR LIFE!
The round clip thing is actually somewhat attached to the hose. It twirls around and actually I see no way to take it off.
It's about 20* here.
Old 02-13-2008, 03:50 PM
Too Cold NB1.8T's Avatar
Keep It Real
California, USA
The ambient temperature in the engine compartment can be controlled by running the engine (driving the car) long enough, hoses and other parts will be heated as a result, gloves might be required for the R&R portion of the following.
Drive the car around for about 30 minutes and the parts should be warm enough to ease your worries of handling cold brittle parts, take your time and carefully apply simultaneous pressure to both sides of the knurled points on the circular bands at each end of the hose (one end at a time), carefully work/slide the hose ends off, now remove the hose from the plastic bracket.
Reverse the above for installation, suggestion, apply a thin coat of "clean" synthetic grease or oil to each O-ring so that they are not damaged during the installation process.
That is an expensive hose, hope it resolves your car DTC issue.
Old 02-13-2008, 03:58 PM
Lnzbug's Avatar
MINI & NB FOR LIFE!
Do I use a screw driver or other flat type tool (putty knlfe) to pry the middle bracket out?
And yeah, it was expensive that's why I haven't replaced it before now.
Also do you guys know how to get my car out of limp mode? I can't drive this way anymore! A whole week this way and it's killing me! That's why I went & got the part. Thinking it was only getting worse (more cracks and the end popping off)
Old 02-13-2008, 05:12 PM
Keep It Real
California, USA
Do not use anything other than you hands on this operation, squeeze each ring on both sides on the knurled spots and carefully work the hose off.
Limp mode is usually reset everytime you cycle the ignition (turn it of then back on) but limp mode will reappear if the problem still exists, however, once the problem is resolved there will likely be DTC's stored in the ECU, you will need a scan tool or vagcom in order to erase any codes.
Old 02-13-2008, 06:47 PM
Lnzbug's Avatar
MINI & NB FOR LIFE!
I understand about the end rings and having to squeese them. It's the other part that looks like a placement clip that's more towards the middle of the length of hose. Will that just pull out and the new one push in?
Thanks for your help
Old 02-13-2008, 07:01 PM
FineExampl's Avatar
Poopship Destroyer
Edison, Dirty Jersey, USA
I think the center clip isn't even required for functionality, i think it just keeps the hos from moving. Unless the hose is a different part# from the 2.0L hose used for the same purpose. It's a tool-less job though to replace the hose.
LOOK AT MY Bug!!!!
Old 02-13-2008, 07:40 PM
Keep It Real
California, USA
That clamp holds the hoses in place, simply lift up slightly on the top lever portion of the clamp and pull the lower clamp section out far enough to allow the hose to be removed, this part is easier than unhooking the two hose ends.
Old 02-14-2008, 03:19 AM
Lnzbug's Avatar
MINI & NB FOR LIFE!
OK, Thanks guys. I'll have to wait a few days for it to get warmer here. Maybe Friday. I'll tell you how it went after I do it
Old 02-14-2008, 07:18 PM
Lnzbug's Avatar
MINI & NB FOR LIFE!
Well, I did it!! It was a real pain in the you know what but I did it. It was hard to squeeze and push both equally at such a weird angle. The airbox side was alot easier than the other end. I also scanned the car and only got PO411. I cleared it, the light went off and I went for a spin around the block. Aaaaand I'm happy to report no more limp mode or CEL!!!W00t W00t!! Here's a blury pic of the new one. I wasn't sure what to do with the two wires.Thanlk you again for your help!
Old 02-14-2008, 09:20 PM
DannyRandomState's Avatar
Tired.....
State Of Confusion, USA
Car: Wasabi
YAY!
You got 'er done!
Wasn't that bad was it?
3-5 Trucks!!!!!
Old 02-14-2008, 09:24 PM
Lnzbug's Avatar
MINI & NB FOR LIFE!
I think I can take the certification test now Thanks again for the help guys
Old 02-15-2008, 12:15 AM
noR's Avatar
Administrator
Jackson, MS, USA
Way to go Ellen!
Old 02-15-2008, 03:59 AM
Lnzbug's Avatar
MINI & NB FOR LIFE!
WTB: Secondary Air Pump Hose rramirez26 Parts and Accessories 0 11-28-2007 06:42 PM
cold air intake vs ram air intake xXRockyHorrorsXx Styling Modifications 33 09-03-2007 08:55 AM
Turbo-S (secondary air pump hose) part name or # needed uf_gators 1.8 Liter Turbo 1 03-05-2007 03:12 PM
Secondary Air Pump Hose 2000GLX 1.8 Liter Turbo 4 02-23-2006 01:37 PM
missing secondary air hose jazzcat 2.0 Liter Gas 2 11-16-2005 05:38 PM
