Turbo timer; yes or no? - NewBeetle.org Forums
Old 02-27-2008, 06:20 PM
punch_buggy's Avatar
Sellersville, PA, USA
Car: 2001 Beetle Turbo
Default Turbo timer; yes or no?
Is it wise to add a turbo timer or not? If so which one is the best one? Best meaning not the most expensive or the cheapest; just the one to get the job done. I thank everyone for their help and honest opinions.
Fred
Old 02-27-2008, 06:29 PM
noR's Avatar
Administrator
Jackson, MS, USA
If you're stock; it's unnecessary.
If you plan on going big turbo I'd make it a necessity.
If you're pushing the stock turbo to near it's limits, I'd recommend it.
If you do a chip and some suspension mods; I wouldn't recommend it. (But it's NEVER a bad idea; just somewhat unnecessary.)
If you're not going to run a timer, then just 'be easy' on it for the last minute or so before you shut down. Don't come off the interstate after some high-reving crazy stuff and shut it down right away. Maybe light throttle up the off ramp; cruise down the last couple residential streets; etc etc.
Just ease off for a minute or two and the timer's unnecessary (you have an after-run electric coolant pump after all).
noR | me | Phrog
PHROG
Old 02-27-2008, 08:38 PM
Lony's Avatar
Driver found.
Stuttgart, Germany
Car: 2001 1.8t
Just drive the last 2 miles boostless and you'll be fine. Your stock water pump will still run and cool down after turning off for approx. 10 minutes.
It does NOT pump oil through the turbo which is the benefit of a turbo timer but imho if you just care about your car and let it cool down before turning off forget about a really complex turbo timer install (wiring with your ecu and immobilizer is a pita!).
Old 02-28-2008, 09:20 PM
Raleigh, NC,
i know plenty of BT guys that dont have one.. just let the engine idle for a minute or two before you cut it off (or drive easily)
the afterrun coolant pump is not the issue really. you want to keep the oil flowing until the turbo has time to cool off so it doesnt sit inside the turbo and burn up. too bad they didnt add in an after-run electric oil pump...
Apex Tuning
NB 1.8t TB Hose
Old 02-28-2008, 09:32 PM
noR's Avatar
Administrator
Jackson, MS, USA
Yep, but no one said you can't.
Oh and if your door chime still works, it chimes for exactly 1 minute when you open the door w/the key in the ignition. (if you need something to tell you you've been sitting & idling for 1minute)
turbo timer buggin2662 1.8 Liter Turbo 0 01-11-2008 03:19 AM
Passport G-Timer or G tech Pro ?? ophawk Technical Modifications 2 11-30-2007 01:24 AM
please... help me with turbo timer montague Questions, Issues, Concerns, or Problems with the New Beetle 0 07-08-2006 06:20 AM
Turbo timer montague Questions, Issues, Concerns, or Problems with the New Beetle 3 07-05-2006 07:59 PM
Does anyone have a turbo timer Justinb1823 1.8 Liter Turbo 8 02-06-2006 02:01 AM
