i tried the search but it didnt help.
im noticing a burnt coolant smell under the hood and when i looked with a flashlight the two hoses goin into firewall had some wetness on them and it was steaming around the turbo area. is there a coolant hose in that area or something i should look for? i donbt think its oil because it wasnt cloudy smoke like burnt oil, smelled more like coolant my temp light flashed red today too for the first time. so i added coolant and that went away. it was pretty low. any help would be appreciated im new to vw's and turbos. thanks a bunch |
BTW, Don't go driving all over the place with the coolant leaking. The line may burst eventually, dumping your coolant out quick! If you see the light come on make sure you stop in the first safe place and refill. Keep some duct tape around just in case till it's fixed!!!
after i filled the coolant up i drove it a few miles til it warmed up and the cold light went away just to make sure the temp light didnt come back. it was when i got home from then i noticed somethin is leaking back there. so the coolant isnt just pouring all out yet, just a minor leak so far. the coolant bottle was still mostly where it started at after i filled it |
All I can say is, FIND that LEAK! It's prolly the heater lines unless the coolant is coming from the motor side and not the firewall or attached lines. |
Because of the potential of ruining your engine and high price of repair; have your cooling system pressure tested. Generally, when the system is pressurized, the leak will be obvious and the coolant should run out of the leaking area. Then fix the leak ASAP! Most shops don't charge too much for a pressure test of the system; since this is a vw, there isn't a traditional radiator cap; so, the pressure has to be done at the coolant reservoir. Good luck and don't ignore this problem.
$350!!!!!!!! OMG that's but-rape there. So sorry. ![]() |
| Help with coolant leak... | crymsen | 2.0 Liter Gas | 10 | 12-20-2007 02:11 PM |
| Coolant Leak - D/S - Coolant Flange | Scarab 1 | Questions, Issues, Concerns, or Problems with the New Beetle | 17 | 06-28-2007 12:16 PM |
| Coolant Leak? | Ringo* | The New Beetle Experience | 8 | 03-15-2007 10:50 PM |
| Coolant leak - where from? | Audiophil | 1.8 Liter Turbo | 10 | 02-27-2007 03:43 AM |
| coolant leak | lady bug | 2.0 Liter Gas | 4 | 08-08-2006 05:23 PM |
