NewBeetle.org Forums (http://newbeetle.org/forums/)
-   1.8 Liter Turbo (http://newbeetle.org/forums/1-8-liter-turbo/)
-   -   Wiring Print of ... (http://newbeetle.org/forums/1-8-liter-turbo/26930-wiring-print.html)
bmoore106 03-11-2008 01:17 AM
Wiring Print of ...
Thanks for all the help in the past. Does anyone have a wiring print of the 3 wires that go to the thrust sensor located on the charge air cooler? I accidentally ripped them out of the connector while replacing the turbo.:mad:
Item #53 on item #1.
http://www.avtoshop.net/vw.php?mdl=2...grp=1&check=95
Thanks,
Billy
zeusenergy 03-14-2008 07:15 PM
Thanks,
Billy
That site is in russian :)
Why did you take the intercooler out to change the turbo? The part you are talking about is called a pressure sender, I think. That's it's function.
Here's the schematic. Keep in mind I ganked this from somebody else.... for the diode mod I never did. Check out G31, it should give you the answer you're lookin' for:
http://shaw-clan.com/beetlepix/pressuresend.jpg
bmoore106 03-17-2008 11:36 PM
I originally pulled the air cooler to check for oil and it was full. Then I knew the turbo was bad. Thanks for the print, I finally figured it out from a schematic and now the light is gone.
Thanks,
Billy
zeusenergy 03-18-2008 01:46 AM
Thanks,
Billy
Glad to know it's sorted out. Good luck, hope the replacement turbo doesn't break the bank. Maybe it's time for a K04?
