What side of engine are the cam seals on? - Page 2 - NewBeetle.org Forums
  #21 (permalink)
Old 03-27-2008, 07:00 PM
Knoxville, TN,
Note that some engines, the vacuum pump is located on top of the intake manifold, others it is located below the intake.
Pencilneck blah blah blah
OEM Wheel Database....
5052 @ $8000 = total crap
VAG COM @ $350 = sanity
  #22 (permalink)
Old 03-27-2008, 08:08 PM
member
Glendale, CA, USA
Car: 2001 GLX (AWV)
So is replacing valve cover gaskets and cam seals part of a timing belt/water pump relacement?
b
  #23 (permalink)
Old 03-31-2008, 06:10 PM
Knoxville, TN,
b
No. The valve cover is not removed during a timing belt or water pump job.
  #24 (permalink)
Old 04-02-2008, 12:31 AM
member
Glendale, CA, USA
Car: 2001 GLX (AWV)
So I cleaned the throttle body and start-stumble stopped. Replaced the suction pump and it started doing it again. Go figure.
b
  #25 (permalink)
Old 04-03-2008, 08:41 PM
member
Glendale, CA, USA
Car: 2001 GLX (AWV)
By the way, the old suction pump broke apart during removal and did not show any signs of being clogged. It may have malfunctioned but it was not clogged.
b
  #26 (permalink)
Old 04-07-2008, 10:09 PM
member
Glendale, CA, USA
Car: 2001 GLX (AWV)
Cleaning the MAF sensor finally cured the cold-start stumble.
b
DIY: Quiet Your Door Seals SMG Paint and Body 24 04-24-2008 02:44 AM
oil around oil cap and top seals? Audiophil 1.8 Liter Turbo 5 02-21-2008 11:52 PM
Turbo S plastic engine side shields cobrabobby 1.8 Liter Turbo 8 11-05-2006 06:05 AM
Weird noise coming from engine - in front of driver side Blue_00_Beetle 1.8 Liter Turbo 17 11-04-2006 02:24 AM
Headlight rubber seals ozbanana Questions, Issues, Concerns, or Problems with the New Beetle 1 04-18-2006 10:00 PM
