I just wanna know that are there only 24 AWV Engines? If so, anyone knows why
What is engine code in newer 1.8T engine? I know Turbo S is AWP. Is 2003up 1.8T also AWP?
It's not a car, it's Volkswagen. Driver wanted. |
"24 AWV Engines"?
I don't get the question...All 1.8T engines from 2001.5 and on are AWV, conservatively rated at 150hp. The only exception is the Turbo S which has the 180hp AWP, as you stated. |
APH = 150 hp 1.8T 1999 - 2001
AWV = 150 hp 1.8T 2001(all Sports and a few GLXes) - 2006 AWP = 180 hp 1.8T Turbo S only APH + chip = 185 hp AWV or AWP + chip = 215 hp Not sure about the 24 reference, but Aphid dynoed at 134 whp before the chip, so taking into account 15% loss due to the automatic transmission, I'd agree that 150 hp is a conservative estimate.
Aphid has been with us since Sept 7, 2002, and even with over 100,000 miles, she's still going strong! |
Also, i'd like to see the dyno sheets of any NB 1.8t putting out 215 whp with just a chip. Even APR and Revo's inflated whp numbers don't go higher than 207 and 209 whp. |
APR lists 209 hp for the 91 octane program and 215 for the 93 octane program, but does not specify whether that's at the wheels or crank. After Aphid was chipped, she dynoed 168 whp on a dyno on which everyone that day registered lower than anticipated numbers. In fact the only 1.8T that beat Aphid that day was an APRed GTI with a full APR exhaust and a top of the line CAI @ 182. Unless that dyno was that far off, it also makes sense to conclude APRs numbers are at the crank. I hope this clarifies things. ![]() |
Why AWV or AWP + chip give the same hp? Why AWV is on a few GLXes? I saw FallinApartBoy details about the car AWV engine 1 In 24, so I'm just curious what it means? ![]() |
Turbos S motor is already software tweaked from the factory that is why more HPs. But once you put a chip in it all equals out to same as they are same engines really. That is pretty much it simply put.
I have 2001 GLX with AWV motor and i know that not many GLXs have it. I have no idea why, though. Eugene
BeetleT from AZ. Ahwatukee of Phoenix, AZ! Its a dry heat! |
wolfsbürgwe.:Rks Quote:
well i changed my turbo out to the k04 and the one i pulled off of my car was not a k03s just a reg. k03...the engine code is awv and its an 01 sport...i didn't realize awv's had em...guess someone at vw screwed up when they put mine together.
SoCalnewbeetleclub |
there is a slight difference in compression ratio as well as the stock boost level |
