po441 - NewBeetle.org Forums
Old 03-17-2008, 08:52 PM
Default po441
i have this code, 16825- P0441
EVAP Emission Contr.Sys.Incorrect Purge Flow .anyone have any ideas on where to start .. thanks ..
Old 03-17-2008, 09:02 PM
turbos03's Avatar
TX, USA
Car: 2003 Reflex Silver Turbo S... Sold
http://wiki.ross-tech.com/index.php/16825/P0441/001089
16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
Evaporative Emission (EVAP) Canister Sealing faulty
Pipes between Tank Breathing and Throttle Body leaky/blocked
Possible Solutions
Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
Perform Output Test
Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
Perform Basic Setting
Check Pipes between Tank Breathing and Throttle Body
turbo lag n. The period of time between owning a 2.0 VW and trading up to a 1.8T...
Old 03-18-2008, 07:53 AM
thanks , where would one find the, n80 , n115 valve , and the evap canister ?
Old 03-18-2008, 07:52 PM
turbos03's Avatar
TX, USA
http://www.bentleypublishers.com/product.htm?code=vynb
Old 03-18-2008, 11:20 PM
thanks , i got a manual.all it shows on page 26-14 is evap controls schematic but not where they are placed ... ..
Old 03-19-2008, 03:10 AM
I've been buggered.
Timbuktu, NH, USA
The 115 may be behind the rear passenger side fender. Check out "audi tt fuel door or fuel cap" in a search. It's under styling mods I think, you can see the evap system under there. Or check your manual for anything fuel related to find it.
