Yep, probably didn't get new plugs at all. That's what I'd try before digging into anything deeper.
I use some $7 plugs; they work great. Use whatever you like, I forget what they should be gapped to, sorry; but I know someone has it posted. 0.26 or 0.28 I dunno. |
If you know of anyone that does not have two left thumbs around a car you could use this:
Spark Plug Change "how-to" (AWV) It should save you some $$ and is honestly not that difficult. If you do it one time you will be able to do it again in half the time.... |
if it is unchipped, i suggest BKR6EIX, which are iridium NGK plugs.
Definitely a DIY !!! I once got plugs from the Dealer's parts department and they charged $14 per plug! Needless to say I returned them. The gap should be .032. Make sure the plugs are torqued properly 22? foot pounds. You should be able (or somebody should be able to assist you to) complete the job for less than $20 depending on the plug chosen. Also make sure the coil packs (ignition coils) are secure. These are the equivalent of sparkplug wires you may be more familiar with.
SoCalnewbeetleclub |
20V Turbo cover !!! |
| Codes | funky | 1.8 Liter Turbo | 7 | 07-08-2007 12:02 AM |
| Need Help 2 codes | Warnberg | 2.0 Liter Gas | 3 | 07-07-2007 03:23 PM |
| Codes? and how to fix? | Noviisi | 2.0 Liter Gas | 6 | 06-15-2007 05:42 AM |
| need help with codes | bobaganoosh | 1.8 Liter Turbo | 6 | 12-30-2006 04:50 AM |
| Help with CEL codes | bluebee | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 07-03-2006 04:30 AM |
