Temperature & Oil Pressure Lights - NewBeetle.org Forums
Old 04-09-2008, 12:48 AM
JRT
Arlington Hts, IL, USA
Car: 2002 GLS Lifestyle
Default Temperature & Oil Pressure Lights
I have developed a problem with my 2002 1.8 turbo beetle. It started with the temperature light coming on solid blue even after the car was warmed up. It then progressed with the oil pressure light coming on at idle when the temperature light was on. I took it to the dealer and they could find no codes for the problem. They found the antifreeze mixture was wrong and claimed that was causing the light to come on. They had to correct that for free, since I had the antifreeze changed at the dealer. They said the oil pressure light coming on could be caused by sludge buildup. I told them I had used Mobil One on every 5000 mile oil change and also used Volkswagen oil filters. They said the engine could still sludge up, so they did a $300 engine flush. I was driving the car tonight and the problem is still there. Anyone have any ideas what the problem could be with this thing?
Old 04-09-2008, 02:44 AM
LadybugEwa's Avatar
PUNCHED BUG
Toronto, Ontario, Canada
at this time, is your coolant expansion tank level somewhere between the min and max marks?
Here's a look at Ladybug
Old 04-10-2008, 12:06 AM
JRT
Yes it is.
Old 04-10-2008, 12:16 AM
LadybugEwa's Avatar
PUNCHED BUG
I'm thinking 'thermostat' - but I'm no expert on the 1.8 - maybe some of them will pipe up
Outside Air Temperature Sensor JetPuf Technical Modifications 9 08-29-2011 04:34 PM
WTB: Temperature Gauge Kenya_7 Parts and Accessories 0 11-26-2007 11:35 PM
temperature barrabiuri Styling Modifications 7 06-22-2007 01:57 PM
Oil pressure lamp and temperature lamp STB Questions, Issues, Concerns, or Problems with the New Beetle 9 05-23-2006 07:08 AM
Intake Air Temperature mod... mopester 2.0 Liter Gas 1 01-03-2006 10:47 PM
