Hey guys, I recently purchased a 2000 NB 1.8 Turbo. I have run into a few problems, the biggest of which is when I slow down to make a turn or come to a stop light the car will turn off. There is no Check engine light, and the car always cranks right up and she is on her way. Is this a common problem? Has anyone experienced this? Any help would be greatly appreciated! Ohh yeah, the car has 85k miles Thanks Again!
Hi new guy
![]() Is it a 5 speed? Are you pushing the clutch pedal in Just kidding.Are there any other symptoms? Once you start it up again does it idle or die out? Has the timing belt and water pump been changed? Hopefully someone here who is more of a mechanic than I will check in.
i recently had a problem similar to what you are describing. When i would slow down to make a turn or come to a stop a light my car would stall, or sometimes the engine would rev by itself trying to stop from stalling. I had a bad MAF, and once it was replaced it stopped. You might be having the same issues, and this might be what problem is.
Here we go Steelers, Here We Go!! 2-0 Here is Jacksonville, FL new slogan. Jacksonville. Salt Life. We Don't Know what Fun Is. RIP MU http://mysteriousuniverse.org |
Timing belt and water pump were changed before i purchased it. The car idles fine when you restart it , it will just occasionally die when you are coming to a stop...Does anyone know how to "Test" the MAF sensor? |
half of that $ on eBay - pick good seller though
what's your revs when it happens? visual check of your vacuum lines won't cost you anything either ![]()
I had that same exact issue a few years ago. Did two things at the same time, so not sure which one fixed it.
I replaced the fuel filter and the N75 valve. Hasn't it done it since.
Cyber Green. It's not a color. It's a way of life. '00 GLX Cyber Green / Cream, 5sp. (Click for pics!) '07 Audi A3 S-Line Last edited by pdoel; 04-27-2008 at 01:25 PM.. |
1. The T-Belt and water pump will not cause the issues that you are describing.
2. I would not suggest buying a MAF sensor anywhere except the dealer, a company that sells the factor part from a person that you feel comfortable with and rust to be honest, otherwise, you could end up with a used or no good sensor and not even know it. 3. Cleaning a MAF sensor is an easy a cheap and thing to try, however, this will have no effect if the sensor has reached the end of it's life and is not working correctly, replacement would be the only option at that point. There are a number of possible things that might be causing your problem: A) Fuel pump B) Fuel filter C) MAF sensor D) MAF plug E) FPR F) Injectors G) Spark plugs Etc...
i CANT FIND ANY INFO ON THE N75 valve... is there another name for it? |
when i first bought mine i had that problem, took it to the dealer and they idled the car up and it ran fine.
here's a link to the N75, it's a wastegate control valve http://www.ecstuning.com/stage/edpd/...l=&engine=1.8T
Torrey Greene Quote:
Thanks for all the help guys!
We replaced the MAF but that didnt fix it , we are going to do a full tune up on it since i dont know the last time it was done, and go from there... If anyone has anything to add, please keep the ideas coming. Thanks again! |
My 2002 (automatic) also stalls when at a light or after just starting up and putting it into drive or reverse. Sometimes it idles really rough. It has been getting worse since I bought the car in 2005. Now it is starting to chug once in a while. I will be on the highway and it will act like it is not getting any fuel and then I have to pump the pedal a couple of times to get a response. Kind of scary at 60 mph.
The repair shop replaced the MAF sensor, fuel filter, spark plugs, and did a fuel flush. Not sure what codes it has been getting but I am going to ask. I did notice after the MAF was replaced the Turbo did not hesitate as much, but now it is getting bad. Also I noticed when I had the passenger window open I could see a lot of fumes rising. Did not notice it on the driver’s side. Not sure if that is normal (assume not). I am adding to the check list: n75 valve, fuel pump, fpr, injectors, fuel pressure regulator. Any other ideas let me know. I want her to make to Roswell next year! Tammy |
| AC Problem....Help | snoopy | 1.8 Liter Turbo | 5 | 06-22-2007 02:00 AM |
| A/C problem | rscarb2 | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 06-16-2007 06:10 AM |
| AC problem?? | Jellibean83 | 2.0 Liter Gas | 2 | 06-03-2007 02:22 PM |
| odd problem | deadgirl | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 01-07-2007 05:22 PM |
| New Beetle - possible the worst car ever made - problem after problem - PLEASE READ | John Pemberton | The New Beetle Experience | 48 | 06-21-2006 04:41 PM |
