valves - NewBeetle.org Forums
Old 04-17-2008, 08:09 AM
buggin
eancho cucamonga, CA, USA
Car: 2000 1.8t
Default valves
ive got a 100,000 miles and was wondering if anyone else can hear there valves ticking and i took my valve cover of today to replace the gasket y is there two plastic covers over one cam
also replaced my axle today but like any other diyer im second thinking everything i did i torqued everything and used locktite so hopefully i should be good just really parinoid
also installed the forge tip the other day dont know y everyone says its hard took me 20 min to pull the old out and put new in
bigest problem i had was the bootom vaccum line so i just took it off and put it on before i put the tip in the engine bay but well worth the effort
also when i go over speed bumpo i hear a noise like a knock noise from my passanger strut area
Old 04-17-2008, 03:40 PM
"that kid with the bug"
orange city , FL, USA
Car: 2003 new beetle Turbo S and just sold my baby "the beast" a 1970 baja bug i built from the ground up
woah, periods man!
cant really help with anything but the sound... you could have either a worn out strut, a broken spring, or a loose strut mount. but i could still be wrong.
Matt
"DIVINE INSANITY: God killed himself on the cross to save his own creation from his own wrath"-----Author unknown
turbo S: $200.37 a month
intake: free
K&N Xstream: $80.00
embarassing every ricer within 50 miles: PRICLESS!
Old 04-17-2008, 04:14 PM
NYBugman's Avatar
MkV Pilot
Brooklyn, NY,
Car: 08 CW GTI Pkg1 DSG
The ticking sound you hear at idle are most likely the injectors. For some reason, that is a trait of the 1.8T engine.
The axle is totally up to you. As long as you torqued everything to spec you should be fine.
You got away lucky with the TIP. I hear more people talk about their ordeal with their TIP than their quick install.
The knock is probably a worn strut tower mount. Have them replaced. I had the same thing about a year ago and I did the strut tower mounts, LCA bushings, and balljoints put in all at once. If your car has over 100K, and you don't have maintenance records, I would have those bits replaced.
And if you don't learn how to form a coherent paragraph, I will start a petition to ban you
Old 04-17-2008, 04:47 PM
jazzcat's Avatar
Delightfully Tacky
Mesa, AZ, USA
Car: 1997 GTi VR6
clunk is control arm bushings...9 times out of 10
Jim
1997 GTi VR6..its cliche
http://rustisnotacrime.com
Old 04-18-2008, 07:06 AM
buggin
Car: 2000 1.8t
Default well went dragh racings 1/8th mile best so far 9.5 spinng tires in first
had 10 psi in tires got bout 7 runs in and last won hooked up great, good burn out.
but get threw first gear wheels hopped i think as of 12:00 tonight the axle snapped but will know for sure in the morning
all i heard was snap and a loud grinding noise and the inner cv boot was torn and this is a newly rebuilt axle not even a day old
and yes my reaction time sucks= .508 60 ft 2.028
Old 04-18-2008, 01:02 PM
noR's Avatar
Administrator
Jackson, MS, USA
Bummer that; I guess you've got a new clunk to diag now...
noR | me | Phrog
PHROG
Old 04-19-2008, 04:33 AM
buggin
Car: 2000 1.8t
Default took it apart
took me ten min to pull the axle out (fast huh lol)
the inner cv joint broke guess when the rebuilt it the spline where the bearing go was a lil worn.
so when they put the new joint it just skipped over on that last run and shatered everything in the joint.
all is well though just gotta wait for them to find a new axle and rebuild it then ill be back out there
Old 04-21-2008, 03:05 PM
noR's Avatar
Administrator
Jackson, MS, USA
Raxles.com makes some nice looking hardware.
If you'd rather by my used axles at some double-digit fraction of the cost on the raxles; let me know, we could work something out.
I've been wanting to upgrade and the beetle's down for a few weeks.
Bent Valves, Damaged Pistons, Now What?? 5lugRS 1.8 Liter Turbo 16 04-10-2008 11:38 AM
Bent Valves? ssinema 1.8 Liter Turbo 7 01-15-2008 01:43 PM
Aftermarket Diverter Valves...Whatcha Got? KittenPoker 1.8 Liter Turbo 21 03-25-2007 01:46 PM
Diverter valves GENETIX RACING Technical Modifications 3 10-23-2005 04:13 PM
