could also be low coolant that is right on the cusp. When cold you are below the line and the light will beep and flash. As it heats up and expands is crosses the line and turns blue. When it reaches full temp it turns off.
My red light began flashing over the weekend. I called an Org friend, for advice on what coolant to put in, since the resevoir was low. I filled it up, but the light still flashed.
In my case, it was my water pump. I was two weeks out of warranty. But! They covered it! ![]() In your case, as was mine, it could have been a low res, a temp sensor issue, or the water pump. Good luck to you! ![]()
Former VWs: 2002 NB Turbo S - Platinum Gray 2003 NB TDI - Galactic Blue 2005 NBC 1.8T- Tornado Red 2006 Passat 2.0T- Blue Graphite 2003 NB Turbo S - UniRed 2005 V6 Touareg V6 - Campanella White Currently: 2002 NB GLX 1.8T - White Paint |
After a while doing this, you're bound to end up with mostly water in the system. The coolant's supposed to be mixed 50/50 with distilled water AND the coolant IS either leaking or being burned up - the longer you ignore that, the bigger the bill in the end ![]()
Use G12 coolant.. And you need to get it from a VW dealer. I don't believe Autozone or any other parts store sales it. Make sure that you don't mix any coolants.. G12 coolant is red. I bought it from a local VW dealership and it was 22 dollars.
♥♥♥ Candie ♥♥♥
HeatherBug is right G-12 all the way!! Just bought a gallon 3 days ago, had exactly the same problem your describing. If you were close by you could have some.... I only used 2 cups!! $24.99 Yikes!! Autozone has this pink stuff called Dex-cool it's a GM recommended product. DO NOT USE IT!!
Dream as if you'll live forever.... Live as if you'll die today. -- James Dean |
| Temp red light blinking | Paradoxx | 2.0 Liter Gas | 15 | 04-27-2009 07:59 PM |
| Blue Coolant/Temp Light Blinking | markian | 1.9 Liter TDI | 10 | 03-28-2008 03:47 PM |
| Red Blinking Light! | Miss.Panda | Questions, Issues, Concerns, or Problems with the New Beetle | 25 | 04-12-2007 08:39 PM |
| blinking red coolant light with hot air | megantbs | 1.8 Liter Turbo | 8 | 04-22-2006 04:17 PM |
| blinking red light by radio | fatdaddy | Questions, Issues, Concerns, or Problems with the New Beetle | 4 | 01-28-2006 09:44 PM |
