Upgraded Brake Rotors (Larger in Size) - NewBeetle.org Forums
Old 06-13-2008, 04:39 PM
ThePooper's Avatar
Not So Much
Cleveland, OH, USA
Car: Zippy - 2002 Reflex Silver Sport
Default Upgraded Brake Rotors (Larger in Size)
Hi everyone,
I'd like to get larger rear brake rotors for Zippy. A friend of mine mentioned buying GTI rear rotors, but I'm not sure that would work. Anyone have any suggestions? I'd like to go up to a 12" rotor if at all possible.
Thanks!
Lisa
Current Cars: 2002 New Beetle Sport (Zippy,) 1994 Buick Roadmaster Estate Wagon (Woody,) 1992 Pontiac Firebird (Truckbird,) 1991 Chevy Camaro (Money Pit,) 1989 Chevy Camaro Iroc Z
My Website
Old 06-13-2008, 04:49 PM
noR's Avatar
Administrator
Jackson, MS, USA
http://www.parts4vws.com/catalog/pro...nvKit+%2F+Hawk
Takes you from 9.1" to 10.1" rear rotors.
I've no idea where you'd get a kit for 12" rear.
noR | me | Phrog
PHROG
Old 06-13-2008, 05:25 PM
ThePooper's Avatar
Not So Much
Cleveland, OH, USA
Thanks for the reply! And it's still cheaper than the big brake upgrade on one of my other cars.
Old 06-13-2008, 05:34 PM
TheInvisibleDork's Avatar
Recovering Rotary Addict
Bellingham, WA, USA
Car: 2002 Black NB Turbo S
Ron, for shame! ECS sells two 12" rear kits:
http://www.ecstuning.com/stage/edpd/...S%20Stage%201R
http://www.ecstuning.com/stage/edpd/...20Stage%201Rv2
They do recommend that you already have front brakes that are 12.3" or larger, though, so you don't screw up your front to rear brake bias.
2002 Black NBTS
mods: S2000 antenna, chip coming sometime... dunno...
Headlights on all day long since June 2007!
Old 06-13-2008, 05:46 PM
noR's Avatar
Administrator
Jackson, MS, USA
yeah, I don't keep track of ECS, there ya go though.
13" up front, 12" in back?
Old 06-18-2008, 01:30 PM
Yurko's Avatar
blark.
Omaha, NE, USA
Car: 2000 GLX 1.8T
1. 12" rotors in the back aren't going to give you that much additional stopping power, especially when compared to performing a similar upgrade in the front. That, and the stock brakes are more than adequate for a stock engine setup (and even a decently modded one).
2. Are you chipped yet? if not, you can save $100 and have waaaaay more fun if you get a chip.
Old 06-18-2008, 03:06 PM
noR's Avatar
Administrator
Jackson, MS, USA
I'm under the assumption it's being done for aesthtetics, not performance.
Old 06-18-2008, 03:50 PM
NYBugman's Avatar
MkV Pilot
Brooklyn, NY,
Car: 08 CW GTI Pkg1 DSG
Upgrade your pads if you want to stop better. Stock rotors are more than adequate for street driving.
Old 06-20-2008, 04:31 PM
noR's Avatar
Administrator
Jackson, MS, USA
http://www.bahnbrenner.com/vw_audi/p...ke_Upgrade_Kit
Lowers price on a rear upgrade that I've seen yet. bumps you from 9.1" to 11"
Old 06-25-2008, 12:03 AM
ThePooper's Avatar
Not So Much
Cleveland, OH, USA
No engine mods yet, I want to get my brakes upgraded first. It's partially for aesthetics and partially because I plan on modifying my engine. I've had too many friends modify their engines, forget about their brakes and have bad things happen.
I have excellent pads and I don't just do street driving, so I really need to upgrade brakes prior to modifying anything else.
A chip will be the last thing I do.
Thanks everyone!
Old 06-25-2008, 08:34 PM
Yurko's Avatar
blark.
Omaha, NE, USA
Car: 2000 GLX 1.8T
stock brakes should be able to handle anything a chip throws at it. Better pads and SS lines would likely be a more than adequate upgrade.
Old 07-02-2008, 08:52 PM
Too Cold NB1.8T's Avatar
Keep It Real
California, USA
Stock size rear brakes are good for most setup's but I would suggest upgrading the rotor and pad quality.
Stock front brakes should definitely be upgraded because they are not at all up to the task of handling even a stock 1.8t Beetle with an aggressive driver behind the wheel let alone a chipped or more heavily modified 1.8t Beetle.
New Brembo front brake rotors pcb122 Parts and Accessories 0 03-29-2008 02:51 AM
WTB: stock rear brake rotors ninsei Market Place Archives 0 08-08-2006 07:03 PM
Audi TT brake rotors WNAB911 Technical Modifications 5 05-09-2006 03:12 PM
Brake pad/rotors replacment in Calgary? Lunar2002 The Canada Corner 3 03-09-2006 01:30 PM
Best Brake Rotors? afroehle 1.8 Liter Turbo 3 01-30-2006 06:53 PM
