Hi!
Im currently just waiting for the rest of the things I need, before I install the BT setup I got. Now, as per IC, im thinking about a same side FMIC, or a opposite side IC. Ive seen pics about the same side IC, by same side I mean, inlet and outlet are in the same side, that its alot easier to install, than an opposite side one. Now, how bad can i get when it comes to throwing the pipes beside the battery, down to the front? how much trimming is required? Else, ima just go with a same side. Now,how about the size would these fit: 1- Overall size 22.5 x12"x 3" 2-Overall Size: 29 x8 "x3.5" Those both are same sides. If those wont fit, what measures can i be looking for? Thanks! |
I just installed a 28x9x2.75 in mine. IT wouldnt have fit between the rebar support and the A/C consenser if my Radiator mounts wern't messed up from hitting curbs. I'd reccomend a big thin core, like 2.5 or 2.25" x 12 x 24 should be about 28" with tanks on it. If you move your battery over and cut a bit out of the body it's easy to get your discharge pipe through there. So you can get a normal IC not a same side one.
here is my pics and thread. http://newbeetle.org/forums/1-8-liter-turbo/29306-pics-cheap-fmic-install.html |
| Install a turbo Hose on a 1.8T | Davidmoon | Technical Modifications | 0 | 07-09-2008 10:54 AM |
| pics from cheap FMIC install | green02turbo | 1.8 Liter Turbo | 2 | 06-20-2008 08:17 AM |
| possible to install wndow/turbo spoiler on non turbo car? | evamph | Styling Modifications | 10 | 02-25-2008 04:23 PM |
| I could use some FMIC Install Advice/ help | MattP | 1.8 Liter Turbo | 8 | 08-30-2007 07:21 PM |
| Install New Samco Turbo Inlet Pipe | speedsk8er | Technical Modifications | 16 | 11-20-2006 10:01 PM |
