noise - NewBeetle.org Forums
Old 09-07-2008, 06:00 AM
Madison04
Murphy, TX, USA
Car: Aquarius Blue 04 1.8T 5-speed
Default noise
almost everytime i start my car and put it into gear whether it is first gear or reverse it starts to make a screeching noise. what do you think is causing this? thanks much
Old 09-07-2008, 10:56 AM
NBTurboFreak's Avatar
20V GTRS
Car: 2001 Sliver Arrow GLX
Could be the serpentine belt slipping a little. When was the belt and tensioner last change?
MySpace -- Piczo Pics -- WoW
HVWC 2010 Public Relations
Old 09-10-2008, 04:20 AM
Madison04
Murphy, TX, USA
i bought this car used at 11k now its at 44k and i've never changed it. if that is the case, is it a pretty serious problem? thanks again
Old 09-10-2008, 07:16 AM
20V GTRS
Should not be a serious issue unless it breaks then is could cause other problems if it gets caught in a fan or something. If it goes you will loose power steering, a/c, and the alternator.
What's this noise? nicandlance 1.9 Liter TDI 16 12-21-2006 09:15 PM
Is THAT what that noise is ... fulltiltredhead 1.8 Liter Turbo 16 09-02-2006 03:36 AM
What is this noise? nicandlance 1.9 Liter TDI 6 08-16-2006 01:37 AM
Help! Weird noise! kiltedbeetle 1.8 Liter Turbo 7 07-30-2006 11:48 PM
Cooling fan noise esoll Questions, Issues, Concerns, or Problems with the New Beetle 2 05-25-2006 03:47 PM
