boost problems - NewBeetle.org Forums
Old 09-19-2008, 10:26 PM
robpad's Avatar
Miami, FL,
Car: 01 Beetle GLX 1.8t, 06 Passat 2.0t, 02 Jetta 1.8t GLX
Default boost problems
just recently upgraded the software on my 1.8t to Unitronic plus 1. car is only boosting up to 15lbs,the same as before the upgrade. should be up to 20lbs, any ideas what the problem could be?
Unitronic +1/Forge DV,TIP/aFe w/modded air box/3"TB exhaust
DubCartel "Join the Family"
A & L Performance
15075 SW 137 St #10
305-254-1985
Old 09-19-2008, 11:33 PM
sb_beetle's Avatar
CA, USA
Car: 2004 NBC 1.8T
Default Might want to...
check with Unitronic. They're going to have the info on what the software upgrade actually changed as far as boost and fueling etc.
SoCalnewbeetleclub
Old 11-14-2008, 01:05 PM
robpad's Avatar
Miami, FL,
problem solved. switced the N75 valve from the J to the F, boosting up to 25lbs and holding a steady 20lbs
Boost Gauge mojo_trixie 1.8 Liter Turbo 50 04-14-2008 08:21 PM
AC oil boost silverbug99 Questions, Issues, Concerns, or Problems with the New Beetle 1 07-10-2007 07:39 PM
Under Boost Coastie617 1.8 Liter Turbo 5 12-20-2006 09:27 PM
Low Turbo Boost Zarang 1.8 Liter Turbo 3 10-22-2006 11:47 PM
boost? jazzcat 1.8 Liter Turbo 6 12-02-2005 04:18 PM
