I have been working on this one on and off for a year now.
This last item happened 3 weeks ago; at first it had codes stating that the number 3 and 4 cylinders were miss firing and random miss fires. Other codes were ignition control circuit open cylinders 1 and 2. After installing new coils all codes went away for 1 week. Then I had the same codes come backthis time I switched number 1 and 4 coils. The codes for theses two went away but I still have the ignition control circuit open on 1,2,and 3 cylinders. I also checked the injectors and found that number 1 wasn't working. According to my noid lights it is receiving the signal but not working. I pulled off each injector connection and found # 1 wasn't working. With all these different codes is it possible that the cam shaft sensor is barely working or could it be in the PCM. Thank you God Bless The U.S.A. |
I can't beleive it as of today 108 viewings and not 1 reply!
Luckly I did more research and replaced one of the new coils ( it was only 2 weeks old). I also removed the new double platinum spark plugs ; and installed NGK 6458 plugs. Then trimed back the wiring harness on each of the coil wiring plug leads(found 2 wires with cracks in them and taped them up. Now it runs very smooth. I was hoping for at least one reply you folks have been quite heplful in the past. Respectfully sheprr2174 God Bless |
| Bought a 2000 GLX Beetle Turbo | zipster | The New Beetle Experience | 5 | 10-01-2007 09:31 PM |
| 2000 Beetle Turbo 4 SALE! | jerryfanyang | Market Place Archives | 1 | 09-24-2006 09:20 PM |
| 2000 Beetle Turbo | Oyveychris | New Member Forum | 11 | 01-16-2006 02:24 AM |
| what turbo is in the 2000 new beetle | GENETIX RACING | 1.8 Liter Turbo | 4 | 11-29-2005 05:47 PM |
