Throttle Body Clicking - Please Help Me - NewBeetle.org Forums
Old 02-02-2009, 03:04 AM
wgarrett's Avatar
01manbug
West Paducah, KY, USA
Car: 2001 New Beetle 1.8l turbo
Angry Throttle Body Clicking - Please Help Me
I have a 2001 beetle and it is giving me fits. Each time I try to start it the throttle body makes a clicking noise then the EPC light stays on and i have no power. I found a throttle body on ebay and it acts the same way. Any ideas what it could be. Could the battery be bad and the throttle body not geting the juice it needs? It is really frustrating me. Any help would be wonderful.
Old 02-02-2009, 03:08 PM
jackfrost's Avatar
and your little dog too!!
Gurnee, IL, USA
Car: 2000 Cool White glx
have you had it scanned? and the clicking....is it when the vehicle is off or when its running?
Rest in peace rich, no one will ever forget you. fo' shizzle mate......fo' shizzle
quicker than quick, faster than fast i am...wtf, im on fire AAAAAAACK
Old 02-02-2009, 03:56 PM
NBTurboFreak's Avatar
20V GTRS
Car: 2001 Sliver Arrow GLX
Try turning the car to the on position and press and hold the accelerator down for about 5 sec, repeat the process about 3 times. Turn the car off then try to start it. *this works with some models*
MySpace -- Piczo Pics -- WoW
HVWC 2010 Public Relations
Old 02-03-2009, 02:14 AM
wgarrett's Avatar
01manbug
Jackfrost, I've not had it scanned yet. We recently went through an ice storm about a week ago and just got power. But I've got to get it to my guy first, but it won't start. And the clicking is when it is off.
Old 02-04-2009, 07:22 PM
jackfrost's Avatar
Gurnee, IL, USA
how long does it click for a few seconds? almost sounds like the fuel pump went?
do you hear a hum when you open the door? like 1 or 2 seconds worth?
Old 02-13-2009, 03:23 AM
wgarrett's Avatar
01manbug
It is just a quick click. I've had someone turn the key on and I've been under the hood and it is coming from the throttle body. The fuel pump works OK when I open the door. I actually purchase the scan tool and just scanned it below is the result of the scan. Any help here would be appreciated.
Thanks
Wayne
Thursday,12,February,2009,21:50:05:16431
VCDS Version: Release 805.2
Data version: 20090111
Address 01: Engine
Control Module Part Number: 06A 906 032 C
Component and/or Version: 1.8l 5VT NB HS G 3077
Software Coding: 00001
Work Shop Code: WSC 00066
1 Fault Found:
17967 - Throttle Body (J338): Fault in basic settings
P1559 - 35-00 - -
Readiness: 0110 1101
Old 02-13-2009, 04:58 AM
20V GTRS
Try turning the key to the on position (without starting the car), in the VCDS go to 04 Engine and select basic settings. Select block 60 (if I remember right) and wait. This should start the throttle body adaption test. the result needs to be ADP OK.
Remember when you clear a code it resets the readiness codes.
With yours as 0110 1101 the following (1) have not ran or failed or (0) has passed:
0 - EGR
1 - O2 heaters
1 - O2 sensors
0 - A/C (R12) should always be 0
1 - SAI system
1 - Evap (fuel tank vent system)
0 - Cat heating (always 0)
1 - Three way cat efficiency
Old 02-13-2009, 11:08 AM
wgarrett's Avatar
01manbug
NBTurboFreak, I ran the test and the first time I ran it it was OK, I ran it again and it failed, then ran it again and it worked. Where do I go from here? The VagCom is new to me and I'm a bit scared to mess something up. Any assistance it greatly appreciated.
Thanks
FS: Used Throttle Body almsbeetle Parts and Accessories 1 08-04-2010 04:03 AM
Bad Throttle Body? Bret66 Questions, Issues, Concerns, or Problems with the New Beetle 4 07-05-2008 07:51 PM
How to clean throttle body NutterBug 2.0 Liter Gas 4 01-07-2008 05:37 PM
Throttle body replaced!!! ramgarjun 1.8 Liter Turbo 23 06-22-2007 12:48 AM
