OK... Solved one, now another problem - NewBeetle.org Forums
Old 02-11-2009, 10:04 PM
Default OK... Solved one, now another problem
Solved the previous problem.
Now seems to be getting hot. From the time the car heats up a little, both fans kick on, and continue to run until i turn the car off. The coolant fluctuates in the resevoir. Once it runs for a little bit it boils in the resevoir. Once the car cools, the water/coolant drops to almost empty. I add more, drive it and the process starts over. All the while NO leaks.
Timing chain went 3000 miles ago. New top end, water pump, tensioner, etc.
Doesn't seem to be leaking anywhere, doesn't go into solid red overheat warning. Low coolant warning for about 2 minutes then goes off.
Noticed while running that the fluid level in the coolant resevoir fluctuates from 1/4 to completely full. Actually pushing water out.
Any ideas...?
Old 02-12-2009, 03:00 AM
Thanks for all the assistance... Got it fixed.
Old 02-13-2009, 03:24 AM
'01vwbeetle's Avatar
I gots a new dub!!
Maysville, OK, USA
Car: 2003 VW Jetta
What did it turn out to be?
2001 VW Beetle GLX aka Sasha. She will be missed!! She is gone but not forgotton!!
Old 02-15-2009, 06:06 PM
Turned out to be the T-Stat. This was a new one, about 2,000 miles since it was installed by the dealer.
p1296 solved!!! Audiophil Questions, Issues, Concerns, or Problems with the New Beetle 26 11-09-2011 10:53 PM
Yay! I finally solved my bug's hesitation problem! LadybugEwa The New Beetle Experience 7 11-03-2008 11:09 AM
99 CEL p0171 solved!! finchave 2.0 Liter Gas 2 05-08-2008 01:40 PM
Crimes solved... thanks to a 2003 VW New Beetle. dunno513 The New Beetle Experience 7 03-01-2007 11:02 PM
Problems Solved!!! faithola Questions, Issues, Concerns, or Problems with the New Beetle 9 06-10-2006 11:37 PM
