2003 VW Beetle Turbo 1.8L - NewBeetle.org Forums
Old 04-30-2009, 07:41 PM
Alexandria, VA, USA
Car: 2003 VW Beetle Turbo
Exclamation 2003 VW Beetle Turbo 1.8L
Hello Everyone,
I need help, I just purchased a 2003 VW Beetle Turbo 1.8L. I took it to go through emissions and it failed. Prior to doing that the check engine light came on and won't go off. So I decided to play Nancy Drew and buy a car code reader to figure out what's wrong with my car. I keep getting the code P2181, which is the Cooling System Performance. I've checked the coolant and changed it out. Still getting the same code and the check engine light won't go off. Please adivse because I'm about to pull my hair out. Thanks.
Old 04-30-2009, 07:46 PM
kaiser's Avatar
no longer use this site
torrington, CT, USA
Car: 01 techno blue t3/t4 big turbo
it's either the coolant temp sensor or the thermostat, the performance code is usually the thermostat.
sold the beetle, don't use the site anymore
Old 04-30-2009, 08:01 PM
Alexandria, VA, USA
Thank you. I will look into this right away. To be on the safe side could replace both and call it a day?
Old 04-30-2009, 08:16 PM
kaiser's Avatar
torrington, CT, USA
can't hurt, neither are expensive.
a bad cts (coolant temp sensor) will usually cause your car to run rich and a bad t-stat usually stays open and makes the car run too cool.
Old 04-30-2009, 08:20 PM
Alexandria, VA, USA
Thank you. Looking for my parts now.
My 2003 White Turbo Beetle! HeatherBug Photos: New Beetles 172 01-02-2010 08:27 PM
2003 VW Beetle GLS Turbo ananas New Beetle Classifieds 3 10-03-2008 12:31 PM
2003 Turbo Beetle? gerrycorchado 1.8 Liter Turbo 5 06-07-2008 10:05 PM
2003 VW New Beetle Turbo S pgkendall Market Place Archives 7 07-13-2007 09:38 PM
2003 VW Beetle Turbo jkellaway New Member Forum 4 12-18-2005 10:37 PM
