Well I got the cylinder head off yesterday, and all four cylinders have valve strikes. I did have one surprise, I thought that the 2000 APH was a 16 valve and Cowboys' is actually a 20 valve.
I did not like the first set of DIY photos, so I took some more today and those where better; so as soon as I get them annotated I'll post them. There was a moment yesterday when I realized the head was not going to come off and my neighbor pointed out that I missed a bolt. I do not have a pic of it, but on CCH DIY 015 it is just to the underside of the intake opposite of #1.
My NB Family... Last edited by D2Beetle; 09-21-2009 at 05:08 AM.. |
Here are some close up cylinder head pics showing the bent valves. My next steps are to remove the exhaust and intake manifolds and teh secondary air pump valve, before sending it in to be re-manufactured.
Last edited by D2Beetle; 10-04-2009 at 03:27 PM.. Reason: Added textual instructions for the pics |
Well the cylinder head is off, but before I can send it to Frank Irving to be repaired I need to remove the SAP Solenoid Valve, Intake and Exhaust Manifolds and the Timing Belt Tensioner.
Step Twenty-Eight: [CCH DIY 090] Remove the SAP Solenoid Valve; three hex screws and wa-lah. Step Twenty-Nine: [CCH DIY 091 thru 095] Remove the intake manifold; two bolts and eight hex screws. The intake is some what heavy so pay attention and do not let it fall. I also added a couple of pics showing the injectors; just so you could see what they look like from the inside. Step Thirty: [CCH DIY 096] Remove the exhaust manifold protective cover; the ones you loosened in Step Nineteen. Step Thirty-0ne: [CCH DIY 097 thru 099] Remove the exhaust manifold; there are thirteen bolts. The exhaust manifold is also heavy so pay attention and do not let it fall. I also added a couple of pics just so you could see what it looks like from the inside. Step Thirty-Two: [CCH DIY 100 and 101] Remove the timing belt tensioner; one hex bolt and wa-lah! YOU ARE DONE REMOVING AN APH CYLINDER HEAD!!! [CCH DIY 102 and 103]Now you get to clean the engine block mounting surface so you can reinstall the replacement cylinder head. Last edited by D2Beetle; 10-04-2009 at 03:29 PM.. Reason: Added textual instructions for the pics |
Drop off to Frank Irving has been scheduled for the 24th.
In the mean time I'll be cleaning the block surface in preparation for re-assembly. I also have two secondary tasks... 1) Oil pan replacement 2) Check the Turbo for leaks to determine why there was so much oil in the bottom of the intercooler and in the intake manifold. |
Well I got the head dropped off at Frank's this past weekend and by the end of the week he'll let me know what the consequences are to the previous owners actions.
I just finished this project myself on a 2000 1.8T with all 20 valves bent, damaged primary cam shaft and 6 damaged lifters. P.O. decided to only replace the timing belt and the tensioner seized shortly thereafter. When I got to this point and sent the cylinder head to the machine shop, I pulled the bottom half and transmission out to do the inspection and clean-up. I can't tell you how much easier it is to work on and re-assemble with the engine on a stand. The timing belt, tensioner, waterpump is a 20 minute job. Also, the car has 121K miles so it was the perfect time to replace the clutch assembly.
Hope the head news is good!! |
So how is your NB running now? Better? Worse? Cannot tell a difference? ![]() I hope my head news turns out not so bad. |
Yeah, you can definitely do the work with the bottom half in but after seeing how hard a hit my engine took to bend all the valves I thought it was better to take a close look at the rods and bearings. Also wanted to make sure any debris that may have fallen into the pan wasn't also in the oil pump, etc. So I took the opportunity to clean everything back to nearly new condition before reassembly. I really only wanted to do this once.
I've put about a 100 miles on the rebuild so far but everything seems real good (fingers crossed). I really like the engineering in this car.... a bit more advanced than the '68 Beetle I had in high school. |
well get this... so the car was dropped off in my driveway by a flatbed last February completely dead after sitting for the prior six months in the snow. Pushed it into the garage and began to take it apart. Fast forward to two weeks ago and the moment of truth... starts right up with a 1/4 tank of year old stale gas.... |
![]() I'll be posting my restart attempt on YouTube and hopefully my result will be the same. |
Well Frank has provided me with the "Good News and Bad News"...
... The Good News: ![]() Only 12 of the 20 valves are bent and the exhaust side cam and lifter look good as well. ... and The Bad News: ![]() Here is Frank's commentary and recommendations for the intake side... "The lifters that are damaged are the 2, 5, 8 and 11 lifters. Those are the middle intake lifters for each cylinder. The wear patterns on the camshaft are less apparent, but identifiable. The outside edges of each center lobe are worn. If you notice, in the picture CCH DIY 011, there is also pitting on the #10 cam lobe." So it looks like I need a new intake cam, ![]() |
How many miles are on these parts? I think the wear seems reasonable considering the interference especially if there is 100K+ on stock parts. GREAT news that the cylinder head is good!
Thanks, and you are right; the head rebuild on my '98 2.0 was easy compared to this one and as soon as the weather warms up a bit, 50's or higher, I'll be back into it.
Hardey's MoToRwErKs- The only place to trust your VW/Audi to in Metro Denver
Glad to know, I look forward to hearing mine start for the first time.I'll re-start on mine around the end of March beginning of April. |
| YES, I did it! - Timing belt, water pump, accessory belt. | antonym | The New Beetle Experience | 22 | 10-11-2011 04:50 AM |
| Water pump, timing belt, tensioner, accessory belt replacement | grumblebunny | 2.0 Liter Gas | 30 | 04-25-2011 05:49 AM |
| Timing Belt | c-moon | Questions, Issues, Concerns, or Problems with the New Beetle | 6 | 12-19-2008 08:57 PM |
| Head gasket set w/ head bolts, an orphan tire, and timing belt changes :-) | Porkchop | Parts and Accessories | 1 | 09-21-2008 04:01 PM |
| Stereo rework | afinley | Car Audio | 4 | 12-26-2007 07:04 AM |
