Camshaft Sensor Error - NewBeetle.org Forums
Old 05-03-2009, 01:31 PM
Peter T's Avatar
Brighton, MI,
Default Camshaft Sensor Error
I am getting Error Code from a cheap code reader. It tells me Camshaft Sensor pos.-sensor=>Sensor G40 Implausible Signal. This after I did a head gasket and valve job after a timing belt failure. It is not starting correctly,it will turn over without starting and sounds like a few little putts but not backfires. I stop the car from turning over and try it again and it will start.
Peter T
Camshaft alignment for TDC Peter T 1.8 Liter Turbo 4 05-03-2009 01:35 PM
Camshaft sensor location on 99 beetle 2.0L DonM77 2.0 Liter Gas 6 03-03-2009 07:46 PM
camshaft sensor / engine wiring harness megantbs Questions, Issues, Concerns, or Problems with the New Beetle 1 01-21-2007 04:10 AM
p1340 crank/camshaft position sensor megantbs 1.8 Liter Turbo 0 10-29-2006 11:06 PM
camshaft position sensor - CEL sequoiagrapeboy 2.0 Liter Gas 3 02-16-2006 01:16 AM
