Hello All,
Newbie here. My wife & I just bought our 1st NB, a '05 1.8T NBC. THe car is currnetly in for its 20K mile service & I'm home reading the owners manual. Question - the owners manual says the 1.8T uses "special" turbo oil, that you can only buy at Volkswagen - is this really true? Do I really need to buy engine oil from Volkswagen? What's so special about thier oil for turbo cars? Other manufacturers use turbos. What oil do you use? TY in advance for your comments/suggestions. Regards, JIm |
many oils out there, but not as many that meet the VW oil standard...502 00
I use Mobil 1 0w40. ![]() here's a pdf file from tdiclub on some additional options... http://pics.tdiclub.com/data/529/Aud..._Oil_Chart.pdf
Warren "And I think it's gonna be alright. Yeah, the worst is over now, the mornin' sun is shinin' like a red rubber ball." ![]() 1966, Paul Simon & Bruce Woodley. |
You use 0-40?
So what is 5-40 Euro blend? Only the 5-40 I've seen show VW, BMW & Mercedes Certified. Never on a 0-40?
2003 Turbo S "Speed has never killed anyone, suddenly becoming stationary... that’s what gets you.” - Jeremy Clarkson |
not sure what you mean by 5-40 Euro blend...??? |
We just changed the oil in my 03 1.8 Turbo ....
I used what someone on here recommended 0W40 for summer/ 5W30 best for winter synthetic...royal...something, in a purple bottle?! Could not find Mobil 1 .... and this seems to be fine!! It was a little more expensive, and I have no idea what previous owner used.... I live in Oklahoma so it's already getting hot here, and that is what weight was suggested to me for summer oil. Good luck!
...beep beep a beep beep ~yeah.......
0W40 gives you the benefit of a very thin viscosity at start up *the 0 part* and the thickness required when the engine is at full operating temperature. People forget or don't realize that with modern cooling systems engines reach the identical operating temperature no matter the outside temperature.
So running a 5W30 in the winter means you are actually running a thicker viscosity on those cold mornings and have less protection once the motor is up to operating temperature. I just use 0W40 year round. I used to use the Pentosin 5W40 in the summer and 0W40 in the winter. This was more a matter of convienece than necessity because it just lined up that in the spring I was ordering stuff from OEM / Performance Parts for Volkswagen, Audi, and BMW - ECS Tuning and I added an oil change kit at that time. |
UNLESS YOUR ENGINE IS BUILT use 5w40 synthetic FOR GAS ENGINES!
TDI motors use a different crankcase vent system and HAVE DIFFERENT INTERNALS for it needs thicker oil 18t gas engines use 5w40, you can go with any company i use castrol cuz it's by far the best...... castrol is used in porsches THE FACTORY RECOMMENDED is because the company gets sponsored by mobile 1 to put their name for "RECOMMENDED USE" anywho, yeah, use thicker oil it'll take a longer time to go through the orifices in your engine to lubricate it so yeah, there you go ![]() p.s. viscosity is not what the number before the "w" refers to, it's a POUR POINT. how fast does it pass through the orifice in seconds....so don't confuse THICKNESS with pour point pls ![]() there is a 5w40 mobile 1 diesel blend as well, DON'T USE IT thanksbut of course everyone has their own preference, I PERSONALLY having a built 18t and being a performance mechanic, for daily driving STOCK CONFIGURATION use 5w40 synthetic, regardless of recommended company in hotter climates the viscosity is reduced, so the pour point doesn't have to be that low? if that makes sense....so in hotter climates you may even go up to 15w40 colder the climate you may use 0w60 and that's what i use in winter chicagothanks for reading
I'm your BMW/VW/AUDI mechanic! Ask me Anything! jongperformancejcauto@gmail.com JC Auto Inc. 1937 E Court St. Kankakee, Il Last edited by BigBlackBean; 05-30-2009 at 06:40 PM.. |
The oil viscosity used should be largely base on the ambient temperatures in your geographical location, synthetic oil is more forgiving here due to it's circulatory superiority (I.E.), a slightly thicker synthetic will typically circulate as fast or faster than a slightly thinner organic.
Due to the sludging issues that this engine has, oil for the 1.8T MUST be VW 502.00 spec 5w-40. Any 0w-40 oil that is also 502.00 will also work. The larger oil filter should also be used.
Folks using Royal Purple or other 5w-30, 15w-40 oils are asking for trouble. VW spec 502.00 oil only.
When I went to Advance Auto for the Mobil 1 special, they concurred that I needed API SJ spec and we discovered Mobil 1 did not meet this requirement. FWIW Castol synthetic did. For what ever reason, the example image on the same page in the ownwers manual shows API Service SH. Isn't that misleading? So, whew did you find your information? Where is VW promoting Mobil 1? I think I need to use Castrol with the SJ spec. Am I missing something? Gen
You never know how much you can love a beetle until you own one. |
VW 502 00, or Vw 500 00, or VW 501 00; ACEA A2 or ACEA A3; or API Service SJ... API service ratings are a topic for another thread, i think, but there's more info here: http://www.aa1car.com/library/API_ratings.pdf the current standard is API Service SM, "for all automotive engines currently in use." The Mobil 1 oil does, however, meet VW standard 502 00. don't think vw is promoting any particular oil. i used the info in this link: http://pics.tdiclub.com/data/529/Aud..._Oil_Chart.pdf which is an audi technical bulletin entitled: Engine Oils Which Meet Audi Oil Quality Standards VW 502 00 and VW 505 01...there are a number of brands that meet the standard. i've used both castrol syntec & mobil 1 in my beetle, and generally run the "big" Mann/Mahle oil filters from ECS, although i've also used the Mobil 1 and purolator filters from time to time. 126K miles. evaluate all the information you can find here, the vortex, oil websites, etc. then buy the oil you're comfortable using. |
Gen |
Redline is an excellent synthetic oil for this car, I have used it on many cars including my Beetle with no ill effects, I have seen it shelved, sold and used by different VW and Audi dealership parts and service departments.
I am currently using "Total" (Elf) Quartz Energy 9000 as a result of many recommendations from a number of trusted, experienced Motor-sport facilities. If availability is an issue for you then do what I do, buy/order a case or two at a time and replinish before you run out. |
| New Beetle Hot Wheels "Special Edition" | 00132936 | NewBeetle.org en Español | 2 | 05-28-2008 06:50 AM |
| Volkswagen brand roof rack & "basket" | RDTR1P | Market Place Archives | 2 | 05-13-2008 05:55 PM |
| Britney Spears "M+M" Special Shows | niki | Miscellaneous Hoo-Ha Archive | 26 | 05-07-2007 04:07 AM |
| Police driving Volkswagen Beetle: "Stop or we’ll toot!" | BlueMartian | Miscellaneous Hoo-Ha Archive | 1 | 06-29-2006 12:45 AM |
