1.8t engine oil specs - NewBeetle.org Forums
Old 08-21-2009, 02:02 PM
Car: 2002 VW Passat GLS Station Wagon
Default 1.8t engine oil specs
Hi
I live in the Caribbean, and I have a 2002 VW Passat with a 1.8t engine. I'm not the original owner of the car, it has about 45 000 miles.
I'm having some trouble to find the kind of oils listed in the VW updated list before the "oil sludge" problem.
The last oil change made to the car was with an european syntethic formula: Turboplus 10w40 and the big oil filter. Now, I've found two more syntethic oils: Castrol Syntec SAE 10w-30 and Havoline Syntethic 10w-30, but none of them have the VW 502.00 standard listed in the label. Is there any problem to use one of those oils in the next change?
thanks
Alex
Old 08-21-2009, 05:14 PM
miffmole's Avatar
NBC Driver
SC, USA
Default 502.00
Here's a 502.00 list:
http://pics.tdiclub.com/data/529/Aud..._Oil_Chart.pdf
Old 08-21-2009, 05:44 PM
Thank U miffmole, I'll print the list and go for it, there must be some of those out there
Old 08-23-2009, 05:48 PM
OneFiftyThree's Avatar
Millville, NJ, USA
Car: 2002 NBS
Red face Newbie Here
Originally Posted by alexpm View Post
Hi
...and the big oil filter.
Alex
What is the application for the "BIG" oil filter? Part #? How can I get one.
Thanks
FF
OneFiftyThree - NewGermanPerformance - APR - Bilstein - TyrolSport - Hotchkis - StopTech - SouthBend - 42DD - BlackForest - 153
Old 08-24-2009, 04:02 AM
Default explanation about the "big oil filter"
OneFiftyThree, the use of the "big filter" is related to the problems VW is having with tome of their engines, specially the 1.8t. The sludge problem in the engine is caused (this is what I've read) by the sludge formation because of oil cooking due to the high temperature that turbo engines produce. Some people say this is an engineering issue of the engine. Anyway, to reduce the risk VW has issue and advice to all the customers and dealers to use only synthetic oil (burns at higher temps.) and use the bigger filter to increase oil circulation inside the engine.
The part number for the big filter is: 068 115 561 B (picture here: http://www.hzyunhai.com/UploadFile/20077710357995.jpg)
The small filter part number is 06A 115 561B (picture: http://www.made-in-china.com/image/2...A115-561B-.jpg)
Try to use original parts from VW.
I hope this could help you.
Old 08-26-2009, 03:25 PM
Millville, NJ, USA
Car: 2002 NBS
Thumbs up Look for the EIGHT.
068 115 561 B = BIG
06A 115 561B = small
Thanks, I need that.
Tags
1.8t , oil change
Specs JSznazzy 1.8 Liter Turbo 0 02-15-2009 08:40 PM
Torque Specs jklassen 2.0 Liter Gas 3 11-28-2006 12:37 AM
Specs? PunkinBug Styling Modifications 13 11-15-2006 08:06 PM
break specs A. Onassis 1.8 Liter Turbo 0 04-15-2006 06:25 PM
Trying to get some specs 01GLXTURBO 1.8 Liter Turbo 12 12-31-2005 01:44 AM
