Have you done any mods to the car?
Is the gasket plump and flexible, or flat and brittle? The obvious indication for the oil leak, is excessive pressure inside the motor. If the CCV valve is stuck closed, the pressure will build up until the oil if forced out.
I have been accused of many things, sane is not one of them. |
Could be burning it via the turbo if there is a bad seal, also there is an oil hose on the front of the head below the intake on the driver side (dont remember the name off-hand) that and leak oil under pressure if it starts failing.
Doing this from memory. The CCV is a black "hockey puck" located on top of the valve cover on the Right side. A short hose runs from there back to the intake. Oil can leak if it is cracked or loose. The CCV can be removed by pulling straight up. Use solvent to clean, then use compressed air to gently dry it. Be Careful as the insides are tender.
| That unique VW smell....? | swat253 | Questions, Issues, Concerns, or Problems with the New Beetle | 33 | 07-29-2011 09:32 PM |
| Try losing your VDUB like this... | SPIRU | Miscellaneous Hoo-Ha Archive | 21 | 04-30-2006 07:31 AM |
| emission smell | surfs up | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 01-24-2006 03:10 PM |
| Laundry: How do I get the smell of Gasoline out of clothing? | CrazyJames | Miscellaneous Hoo-Ha Archive | 21 | 11-25-2005 06:32 PM |
| New-car smell is going away | PhoenixRising | Miscellaneous Hoo-Ha Archive | 9 | 09-28-2005 06:32 PM |
