how to...fuel pump - NewBeetle.org Forums
Old 12-08-2009, 02:54 PM
Default how to...fuel pump
I think my fuel pump died. I have ordered the original. I want to change it this weekend.
Does anybody know how to change it and help me?, Any special instructions. Beetle 2000 1.8t
I know it is below the backseat...
Thanks
Old 12-09-2009, 02:17 PM
Lnzbug's Avatar
MINI & NB FOR LIFE!
Arlington Heights, IL, USA
I really think its a plug & play. Just have a bucket or a pan waiting in the back seat so you don't spill any gas in the car when you pull it out.
Old 12-09-2009, 03:18 PM
noR's Avatar
Administrator
Jackson, MS, USA
Sorry I haven't done the procedure before. I have no idea what you're in for.
I'd probably disconnect & reconnect the fuel filter to release any pressure in that line. But aside from that I don't have any ideas.
noR | me | Phrog
PHROG
Old 12-15-2009, 12:22 AM
Champlin, MN, USA
Car: 2001 GLX
I don't have time to go out and take pictures right now (nor do I want to given that its about 2ºF outside), but later tonight when my car is in a heated garage I'd be happy to.
Here are the steps:
1. remove the fuel pump fuse (no. 28)
2. Attempt to start engine, it should die immediately
3. lift back seat and fold back carpet cover
4. unscrew the three screws holding the pump cover
5. mark the position of the pump and transfer marks to new pump, remove lines and connector
6. loosen black outer ring, swap in new pump making sure the sealing surface is clean (you'll have to move the fuel gauge sender from the old pump to the new)
7. connect lines and electrical connector
8. the rest is reverse (remember to reinstall that fuse!)
Good luck,
Matt
2000 New Beetle GLX - 1.8T (APH) - A/T - Black
2001 New Beetle GLX - 1.8T (AWV) - 5 speed - Silver
Old 12-15-2009, 04:57 AM
turbobeetle2000's Avatar
Default Fuel pump or fuel relay switch
I have a similar problem with my 1.8 2000 turbo and would like to know if you could help / no crank no start - no fuel pump sound when you open the door or turn the key / no click / no cranking / all the lights and everything else works / main fuses above battery are okay / didnt have a fuse diagram to check the fuses by the door and dont know which relay under the dash is for the fuel pump / how can I tell if its the fuel pump relay switch or the fuel pump / or could it be something entirely different. The car was fine yesterday / battery about 2 months old. Just wouldn't start today - stranded far from home so I need a quick and easy fix. Thanks
Old 12-16-2009, 09:46 PM
alexvilla's Avatar
beetle @lex
El Paso, TX, USA
Car: 1.8T
Here are the steps:
Good luck,
Matt
WOW that is easy... great write up just need pics !! ...
Parting out mods...
http://newbeetle.org/forums/new-beet...tml#post703989
COMPLETE VOTEX KIT FOR SALE!
http://newbeetle.org/forums/parts-ac...-kit-sale.html
Old 12-17-2009, 06:08 AM
NBTurboFreak's Avatar
20V GTRS
Car: 2001 Sliver Arrow GLX
Here are the steps:
Good luck,
Matt
I would like to add the you may also want to pick up a new sealing ring. Just in case it is damaged when the pump is removed. If it is not then you should be able to take it back and get a refund.
MySpace -- Piczo Pics -- WoW
HVWC 2010 Public Relations
Old 12-17-2009, 03:39 PM
alexvilla's Avatar
beetle @lex
El Paso, TX, USA
Car: 1.8T
Cool, thanks
If I change it, it will be to upgrade it, so which one you recommend??
Old 08-20-2011, 07:00 PM
99bugfan's Avatar
Orangeville, ON., Canada, Orangeville, Ontario, Canada
Car: 1999 Beetle
thanks guys, this should help me do my pump as well.
VW........First there was air, now there is water.
Fuel pump funky 1.8 Liter Turbo 17 11-26-2011 02:20 AM
fuel pump classic396@sbcglobal.net 1.8 Liter Turbo 4 10-01-2009 05:38 PM
is my fuel pump going?? petes Questions, Issues, Concerns, or Problems with the New Beetle 2 03-23-2009 08:50 PM
fuel pump milton 1.8 Liter Turbo 5 12-16-2008 09:32 PM
air pump problem cause a p1137 long term fuel trim (add) fuel bank 1 system too rich jerry kuntzman 1.8 Liter Turbo 4 09-13-2006 04:22 PM
