Need Wiring Diagram 2002 1.8 Turbo - NewBeetle.org Forums
Old 12-11-2009, 07:36 PM
Default Need Wiring Diagram 2002 1.8 Turbo
Got an issue that I am going to need the wiring diagram for. PDF would be nice. Brake light on dash is on along with EPC and check engine. Cruise light won't turn on either and the temp sensor above the mirror won't display. Clock works though.
Yesterday I had a new experience, while sitting at a light I hit the recirculate air button several times. Accidentally, I noticed the cruise light came on and off. Intermittently when I pushed the button the cruise light would come on. Cruise was on but didn't show normally. I am pretty sure I have a bad ground somewhere that connects the brake, cruise and lord only knows what else. Something is back feeding into the brake light and probably the EPC light.
Let me know if you have any suggestions.
Email me direct if you can: h20tension@yahoo.com
2002 Beetle, 1.8T, automatic 112k
Wiring Diagram for Windshield Wipers gprocket 2.0 Liter Gas 4 12-02-2009 08:59 PM
Need wiring diagram for Tach meld Questions, Issues, Concerns, or Problems with the New Beetle 1 05-28-2009 10:18 PM
Help! Need Ignition Switch Wiring Diagram! bxtech Questions, Issues, Concerns, or Problems with the New Beetle 4 03-04-2008 09:35 PM
Does anyone know where I can find a wiring diagram mwilkey13 Questions, Issues, Concerns, or Problems with the New Beetle 5 10-20-2006 12:57 AM
Need Wiring Diagram for 2005 Radio VelvetFoot Car Audio 7 10-24-2005 01:56 AM
