Well the air bag light came on in the wife's '00 NB; I scanned it this morning and here is what VCDS says...
Saturday,16,January,2010,10:30:35:21564 VCDS Version: Release 908.1 Data version: 20091018 -------------------------------------------------------------- Chassis Type: 1C - VW New Beetle Scan: 01 02 03 08 15 17 19 22 26 29 35 37 39 46 54 56 75 Mileage: 265390km/164905miles -------------------------------------------------------------- Address 01: Engine Labels: 06A-906-032-AVC.lbl Part No: 06A 906 032 C Component: 1.8l 5VT NB HS G 3077 Coding: 00001 Shop #: WSC 00066 1 Fault Found: 17965 - Charge Pressure Control: Positive Deviation P1557 - 35-00 - - Readiness: 0000 0000 -------------------------------------------------------------- Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl Part No: 1J0 907 379 AF Component: ASR 20 IE CAN 0001 Coding: 13204 Shop #: WSC 00066 No fault code found. -------------------------------------------------------------- Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl Part No: 6Q0 909 605 A Component: 06 AIRBAG VW5 0003 Coding: 12342 Shop #: WSC 00066 1 Fault Found: 01218 - Side Airbag Igniter; Passenger Side (N200) 32-10 - Resistance too High - Intermittent -------------------------------------------------------------- Address 17: Instruments Labels: 1C0-920-xx0.lbl Part No: 1C0 920 901 F Component: KOMBI+WEGFAHRS. M73 V07 Coding: 07202 Shop #: WSC 00000 Part No: Ident Component: Nr. Wegfahrs.:VWZ5Z0Y1225028 Ident.-Nr. Wegfahrs.:VWZ5Z0Y1225028 No fault code found. -------------------------------------------------------------- Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl Part No: 6N0 909 901 Component: Gateway K<->CAN V072 Coding: 00006 Shop #: WSC 00066 No fault code found. -------------------------------------------------------------- Address 46: Central Conv. Labels: 1J0-959-799.lbl Part No: 1J0 959 799 AJ Component: 5X Zentral-SG Komf. 0001 Coding: 00256 Shop #: WSC 00066 Part No: 1J2959802C Component: 5X Tőrsteuerger. FS0002r Part No: 1J2959801D Component: 5X Tőrsteuerger. BF0002r 2 Faults Found: 00943 - Heated Exterior Mirror; Driver Side (Z4) 35-00 - - 00944 - Heated Exterior Mirror; Passenger Side (Z5) 35-00 - - -------------------------------------------------------------- Address 54: Rear Spoiler Labels: 1C0-959-733.lbl Part No: 1C0 959 733 B Component: Heckspoiler 0002 No fault code found. -------------------------------------------------------------- Address 56: Radio Labels: None Part No: 1C0 035 180 E Component: RADIO 3CP 0001 Coding: 00403 Shop #: WSC 07110 2 Faults Found: 00852 - Loudspeaker(s); Front 36-10 - Open Circuit - Intermittent 00853 - Loudspeaker(s); Rear 36-10 - Open Circuit - Intermittent End -------------------------------------------------------------- Anyway I think the extreme cold (single digits to low 20's) we had during the Xmas and New Year holidays has taken it toll on my NB's.
My NB Family... |
17965/P1557/005463 - Charge Pressure Control: Positive Deviation
Possible Symptoms Reduced power output Limp mode Possible Causes Boost Pressure too High Hoses/Pipes incorrect connected, disconnected, blocked or leaking Charger Pressure Control defective VNT (variable nozzle turbo): nozzles stuck Solenoid Valve for Boost Pressure Control (N75) defective Possible Solutions Check Hoses/Pipes to/between Components Check Solenoid Valve for Boost Pressure Control (N75) Check / Clean / Replace Charge Pressure Control Check / Clean mechanism for variable nozzles
turbo lag n. The period of time between owning a 2.0 VW and trading up to a 1.8T...
| Oh dear, I feel my transmission is going out | savethebluths.org | 2.0 Liter Gas | 7 | 12-09-2009 04:39 PM |
| Dear diary | mel72349 | Jokes | 3 | 10-24-2009 07:38 PM |
| Dear Abby.... | jdesigns | Jokes | 11 | 03-20-2008 01:57 AM |
| Dear Kotex... | hyakugojyuuichi | Miscellaneous Hoo-Ha Archive | 100 | 03-27-2007 07:40 PM |
| Dear IRS | skittle buggy | Miscellaneous Hoo-Ha Archive | 19 | 02-03-2006 02:54 PM |
