well... the sound u like is the air being blown out of the blow off valve... now since 1.8t vw engines will get wrong readings with a bov, the forge bov/dv splitter is the best option and must be set at 50/50. however it will not have the full effect of the bov in terms of the sound and therefore u might wanna add a p-flo air intake that if matched with the splitter will give u the nice sound and add a couple of horses as well...
FAIL
Yeahhhhhhh... Daddy's here.. Thanks to those who gave great advice as to what I thought I wanted to go with on my girl's ride... Ain't no fail if she's not a car guy..I am,so I'll handle the technical stuff from now on..
Just on here helping my honey
I run a HKS bov on my car..Bovs releases the old boost in the compressor and helps turbos spool up faster. From what I've read,looks like the Forge splitter running 50/50 is the best way to go...But I'm just going with what I'm familiar about modding boosted engines....Planning on doing the P-Flow like what was suggested along with an APR chip..Already bought her a downpipe and will get her a cat-back exhuast as well Last edited by bgp; 02-13-2010 at 02:24 AM.. |
Dump valves dump excess boost when the throttle closes AFAIK, no more. The 1.8T engine doesn't use a dump valve but assumes it will be recirculated, hence the CEL if it doesn't see what is expected if you replace the valve with a BOV.
Cheers Simon |
i installed one on my friend audi a4 it works fine. i switch the blow off valve output with the recirculate one. it give loud sound and no problem yet. its been running since 6 months ago. i am planning to install one on my beetle. waiting for it arrive.
if you like the sound and understand the risk just do it, dont care about others who said bad for engine or sound crap. some people have their own preference. you like it then install it! ![]() |
Here are a bunch of other things I have found to explain BOVs vs DVs
Basically it prevents the compressor from going into surge.
When the throttle is closed rapidly (like when you are doing hard driving),your airlow to your turbo is quickly reduced,which will cause flow instability and PSI fluctuation. Rapid cycling fluctations cause audible compressor surge,which will eventually lead to compressor thrust bearing failure. BOVs use a combination of manifold pressure signal and wastegate spring force to detect when the throttle is closed. When the throttle is closed rapidly,the BOV vents boost in the intake tract into the atmosphere to relieve pressure,eliminating compressor surge. That's the technical fuction of bovs. It's basically a type of surge valve. It just depends of how much mods you're doing on your engine as far as any high boost function. I run one on mine because I'm running higher than stock psi and I have a aftermarket adjustible wastegate actuator and still you cannot hear my bov when I'm doing mild driving as my engine is running into its vacuum range. You can only hear it when I'm into boost,the more boost the louder you can hear the bov vent. So I'm saying if you are running stock boost or a couple of psi past it,you won't really need one. If you're going to be running high boost and have a aftermarket internal or external wastegate or modified turbo,then you just might want to use one. The Forge splitter lets you use the stock surge diverter valve on 1.8Ts and just vent some boost into the atmosphere. The P-Flow helps with itake into the compressor,so that why it lets the Forge splitter valve sound louder. |
Look, I have no idea about this but, THIS I do know.
For one thing, before you go disagreeing with what you have been told, you really should check out some of the history from the guys that have told you that THIS was NOT a good idea. The guys that I am speaking about don't get on this board to bully people. Your fiance asked a question, they answered her. Granted, they could have been a little easier on her with the response, or explained the deal more in detail but, before you do it, I would SERIOUSLY do your research. These guys, will NOT intentionally steer you wrong. The NB, if you haven't already figured it out, is NOT and DOES not always react the same as every other car. (Especially, those that are American made. Nothing wrong with American cars, BUT it's just not the same. THAT should have been your first lesson.) Last edited by Yello_jellybean; 02-16-2010 at 05:21 PM.. |
I do appreaciate any info that I get whether it's a yay or a nay<I think and hope that I'm open minded about that for it to show..
The advice that I've received from this thread has been great. I also have advice from my friends back in my hoemtown that actually have VDub tuner shops as well (that where I'll do my installation)...The yays I have gotten have been from 3 turbo gas powered guys,2 that have U.S. spec engines..The nays have been from the diesel guys...I don't know what the compression ratios are on TDI mills,but usually diesels run a higher compression than gas engines and have a different ignition as well..Plus diesels are more responsive and sensitive to any tweaks if they are turbo engines..That may be the reason that you TDI guys get CELs with any type of bovs as well.. I'm reading what is posted on here,believe me. And I'll ask my VW tuners friends about this as well. |
But I'll tell you this. A VW measures the air and expects the air to be there.
If you vent to atmosphere; what do you think will happen? That's right, you'll go rich. VERY rich. You can do it; but it won't work properly. And it's really unnecessary. Get the girl a Short air intake, something w/a metal pipe. It'll make the DV much louder and you won't really want a BOV. Short of it is: The motor was engineered to NOT vent to atmosphere. So if you think you're better than their engineers, by all means, take on the challenge. Otherwise, just get what works for the system. I hate diodes and MBC's. They're stupid and risky. And on a car such as VW; completely unnecessary. There's no sense in replacing a VERY GOOD monitoring/measuring system with a manually adjusted worm-gear. Same basic reasoning applies. All that in consideration; I run a GFB Hybrid DV/BOV. I just have it cranked WAY over towards DV, and it only vents when the tube's over 12psi. So most of my driving is not affected. Yeah, it probably pops rich when I shift gears at WOT. Then probably causes a second of chaos while the O2 sensor says "it's way rich" and dials back the fuel to accomodate just as I'm engaging the next gear. It's your car, do what you want. But thoroughly think about the reasons and consequences. |
Listen to what noR said above, he knows his stuff. Like he said, if she wants that "sound," get her some sort of short (warm air) intake as it will really increase that sound. Just get a quality non-oiled filter for it so you get decent filtration that won't kill the MAF and sand the turbo. |
(sigh) I know all about diesel engines...Thanks for your help anyway...
Look,my girl's not going to be stock...Besides getting either the Forge splitter or the APR R1 diverter valve,here's the plan: Neuspeed turbo air inbtake pipe for the K03 turbo Neuspeed lower intercooler pipe Neuspeed P-Flow cai APR AWP code ECU upgrade Neuspeed 60mm downpipe Neuspeed 60mm stainless steel cat-back exhaust I got good advice from here,and I get good advice form my guy that has his own VW Tuner shop/website as well. Trust me,anything I do is going to be well-thought out and well planned,and if I don't know stuff,I go to the pros to find out. |
here's some advice from someone that has a "modded and shop tuned" car...
that APR AWP code ECU upgrade isn't going to run to good on her car... she doesn't have an AWP code engine... and you'd be better off getting a one piece TIP and not that Neuspeed lower turbo intake pipe... the inter-cooler pipe is going to do nothing for her, even after the cars been chipped... stock pan-cake pipe flows plenty of air... as does the stock inter-cooler for the K03s... inter-cooler to TB hose is money better spent... CAI does nothing, there's no cold air to be had from inside the engine bay... plus the turbo heats it all back up again... stock air box flows more than enough air... the down pipe and the exhaust are good to go... but you can get better for less money.. what shop is doing the work..??
turbo lag n. The period of time between owning a 2.0 VW and trading up to a 1.8T...
Hmmmmm,do anyone make an aftermarket wastegate,or some trick where you can adjust your wastegate?? |
| What's that sound??? | geezerb | New Member Forum | 0 | 07-10-2007 11:20 PM |
| Does this sound right? | laurabug06 | Market Place Archives | 4 | 02-24-2007 11:39 PM |
| Beep Sound | Hiro32 | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 07-25-2006 04:46 PM |
| With Sound On, Please! | PhoenixRising | Miscellaneous Hoo-Ha Archive | 8 | 03-19-2006 04:34 PM |
| DP Sound | 2000GLX | 1.8 Liter Turbo | 3 | 01-21-2006 05:31 AM |
