Replaced timing belt and it still doesn't start... - Page 2 - NewBeetle.org Forums
  #21 (permalink)
Old 04-06-2010, 12:14 PM
jasonwinters3's Avatar
Calera, OK, USA
Car: 2001 Turbo New Beetle, (wifes)
Here is just some of the damage..
  #22 (permalink)
Old 04-06-2010, 12:29 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
Same as mine, not a big deal. Send your head to Frank Irving for a rebuild.
The only valve groves that you need to worry about is the one in the middle. When you are "sanding" the valve grove from the piston head, be sure that you have a good vacuum cleaner. You are working like you are a Dentist; vacuum suction in the left hand, sanding implement in the right hand. This is to ensure that particles do not get between the cylinder wall and the piston.
Do not use any power assisted tools; this is a hands only job.
Dremel Kit tools that I used.
My NB Family...
  #23 (permalink)
Old 04-06-2010, 02:49 PM
70autostick's Avatar
VW Junky
Car: 1999 GLS 2.sl0w
Get that head taken care of,clean those Ps&Cs assuring there's no hairline cracks,and you should be in good shape
-A new head gasket wouldn't hurt.
  #24 (permalink)
Old 04-07-2010, 01:25 PM
Calera, OK, USA
We did not have the right tool to take off the bolts but he made it work. What size "star" tool does it take?
  #25 (permalink)
Old 04-07-2010, 05:25 PM
D2Beetle's Avatar
NB Yellow Trifecta
Which bolts are you referring to?
  #26 (permalink)
Old 04-07-2010, 05:52 PM
Calera, OK, USA
I wasn't there when he took them out. They top looks likes like you need some kind of star shaped screw driver.
I think they were the ones that were used to hold down the head.
  #27 (permalink)
Old 04-07-2010, 08:33 PM
D2Beetle's Avatar
NB Yellow Trifecta
By chance is it one of these?
  #28 (permalink)
Old 04-08-2010, 12:21 PM
Calera, OK, USA
That looks like it..
  #29 (permalink)
Old 04-09-2010, 12:23 PM
D2Beetle's Avatar
NB Yellow Trifecta
Be sure you get new head bolts, DO NOT Re-USE any head bolts, they have a tendency to snap off.
  #30 (permalink)
Old 04-12-2010, 12:29 PM
Calera, OK, USA
Well it bent all 20 valves and some bucket lifters.. $800.00 but at least were are on our way to getting it running again..
  #31 (permalink)
Old 04-12-2010, 03:33 PM
D2Beetle's Avatar
NB Yellow Trifecta
Ouch!
  #32 (permalink)
Old 04-30-2010, 04:30 PM
Calera, OK, USA
I tried to pm you but your box is full.
Where did you get this socket from?
Thanks
Jason
Replaced radio, now car won't start? chad2261 Car Audio 4 07-21-2009 11:36 PM
Ignition Switch Replaced-Now Won't Start jeff2761 2.0 Liter Gas 4 08-04-2007 10:03 PM
Squealing on start up after timing belt change mrbeetlebrain Questions, Issues, Concerns, or Problems with the New Beetle 3 09-12-2006 12:51 PM
Timing belt replaced what happend? vdubbugman53 2.0 Liter Gas 21 04-28-2006 02:31 PM
