The 1.8T is an "interference engine"(when the crank and cam aren't timed properly there will be valve to piston contact)--you lose a TB and it's pretty much a guarantee that the head will have to come off to be sent out for repairs to the valvetrain. If you want to do a leak-down or a compression test for giggles then go ahead, but sorry, just a new belt won't solve the problem 99 out of 100 times.
I did find this in case anyone else needs it.
Fourtitude Forums: DIY: Transverse Timing Belt, water pump, thermostat... |
I'll be doing mine this weekend.
You´ll need to pull the head of to see what the damage is and have it repaired. TBH it was a waste of time putting a new belt on if 30 ribs had gone, timing damage occurs if the belt is 2 ribs out IIRC (but will run VERY poorly if even 1 rib out).
Cheers Simon |
I wouldn't even waste the time or money in getting a compression test. It will be exactly zero in at least 2 or more cylinders. The head needs to come off and be rebuilt as it will probably look something like this: Bent Valve Blues
My NB Family... |
If you break a timing belt on a 1.8T there is going to be huge damage without any question at all. What is even being debated here? Pull the head, repair the carnage and move on.
Just curious, how many miles on the car?
Have to say, can't believe you made it that far on the original belt and water pump. Supposed to be changed between 60k and 80k miles (usually sooner vs later because the water pumps are highly prone to failure.
![]() Quote:
Indeed!! ![]()
| Water pump, timing belt, tensioner, accessory belt replacement | grumblebunny | 2.0 Liter Gas | 30 | 04-25-2011 04:49 AM |
| Replaced radio, now car won't start? | chad2261 | Car Audio | 4 | 07-21-2009 11:36 PM |
| Ignition Switch Replaced-Now Won't Start | jeff2761 | 2.0 Liter Gas | 4 | 08-04-2007 10:03 PM |
| Squealing on start up after timing belt change | mrbeetlebrain | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 09-12-2006 12:51 PM |
| Timing belt replaced what happend? | vdubbugman53 | 2.0 Liter Gas | 21 | 04-28-2006 02:31 PM |
